Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-21-2007, 01:14 AM
lgalla's Avatar
lgalla is on a distinguished road
How Fast is too fast?
Don't really know where to post this.Here goes.
Ihad parts cut on a commercial machine[Thermwood 10hp].The material was 18mm birch plywood cut at 600ipm.The chatter on the cuts was so bad it added 5 hrs to the unit being assembled as all edges had extreme sanding to be done.If we reduce the IPM to 300IPM the machining cost is double to $160/hr.This is way above the cost of doing the job manually on the table saw.Anyone else find the old traditional way is cost effective compared to CNC?
Larry
Old 04-29-2007, 05:07 AM
nwrepair1 is on a distinguished road
Yes. I have CNC routers and one sliding tablesaw. When I make rectangle shaped cuttingboards for restaurants out of solid phenolic material it is faster and cheaper to do it on the saw. I can get clean no sand edges with the proper blade. Now, if the part list has cut outs or odd shaping, it goes on the router. But you shouldn't be getting bad edges with the CNC router. There should be little or no sanding required. Bad edges are caused by many factors in CNC machining. Improper tooling, bad bearings in spindle , worn collets, and not enough vacuum to hold parts down. If this is not your machine, you need to find another CNC operator. You shouldn.t accept the poor edge quality
Old 04-29-2007, 07:38 AM
ger21's Avatar
As the previous poster mentioned, CNC is not always the answer in woodworking. He's also correct that you should be getting clean edges. I'd look at hold down and tooling, perhaps spindle speed as well.
How fast is this? jmytyk DIY-CNC Router Table Machines 8 02-07-2009 05:41 AM
How fast should I expect this to go? obscurity Stepper Motors and Drives 18 11-27-2005 09:47 PM
Feed too fast? Chunky WoodWorking 1 07-03-2005 08:47 PM
Do you have a fast DSL? Help! ESjaavik CNCzone Club House 11 08-18-2004 09:25 AM
IPT too fast for old equip inthedark General Metal Working Machines 5 01-14-2004 08:17 AM
