| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Read 5Bears talk about THK bearings and SR spec but I'm still a little confused. Continued mention that SR is best for "horizontal guideway". Would that allow me to use it on the Y axis if I had a flat sled design for the head carriage and the 2 rails were in normal flat orientation spanning Y direction? How about if I had a traditional single box gantry with the rails laying flat on the top and bottom faces of gantry (In this case he top rail would be normal flat mounting and the bottom rail would be inverted and the block hanging upside down)? I'm thinking that mounting the rails on the face of a single box gantry would be NOT ok. |
| FYI SR rail flat in normal hor. app. = 100 % dynamic and static capacity side/lateral = 55% of dyn. and 43% static capacity upside down/reverse radial= 61% of dyn. and 50% static capacity pg. 39 THK cat. D-2
__________________ DZASTR |
| Thanks Richard. I read your comments as saying if I was making a Y-axis sled design things would be OK, but any other common y-axis style would be working in a reduced capability range of the bearing. Lastly, I looked through the LM docs at THK here but I can't seem to find the document that you refer. Do you have a link? |
| NC_jimbo, I didn't intend to imply anything, only to provide info. If you size the components properly, you could build it upside down. If you go to the link Gerry provided and check the specs, you may be able to do what you described. Good luck
| Pay attention to moment loads rather than gravitational loads. All else equal, moment loads are the same in all rail/block orientations. Right side up, sideways, inverted, doesn't matter. Rail LOCATION, on the otherhand, does make a difference. Rail/block orientation affects location, so use your discretion. For example, if an inverted rail/block assembly allows you to shorten a lever arm (and reduce the moment force) by 300%, it will more than offset the decrease in load capacity. |
| 4-axis limitations? | OC_ | FeatureCAM CAD/CAM | 2 | 05-17-2007 08:43 AM |
| Demo limitations ? | Redline | Mach Mill | 2 | 07-26-2006 12:50 PM |
| Servo Limitations | nashyboy | Servo Motors and Drives | 4 | 02-01-2006 03:45 AM |
| Driver limitations | WilliamD | General Electronics Discussion | 4 | 10-16-2005 03:44 PM |
| DC motor limitations | rippersoft | RC Robotics & Autonomous Robots | 9 | 09-07-2005 08:58 PM |
