Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-17-2007, 05:29 PM
woodfish510 is on a distinguished road
Igus products
Has any body used any these to build a cnc router? The slides look very interesting. Would like to know how well they would last on cnc?
DryLin
Thanks all!!
Old 04-17-2007, 06:31 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
any links, pictures etc.?
http://igus.bdol.com/drylinn.asp this it?
Old 04-18-2007, 10:18 AM
igus
This is the product!
Old 04-18-2007, 12:20 PM
Looks like neat stuff. However, you better check the specs. There is an accuracy and weight capacity that might not meet you expectations or may be adequate. Depends on app.
DZASTR
Old 04-18-2007, 01:29 PM
which rail system
I'm in the planning stage for my cnc router/plasma. The table size will be around 4ft by 4ft (plus or minus). I was thinking on using the 80/20 1530 extruded profile.
I having a tuff time deciding on which rail to use for the table movement.
Which one would be better to use of the two-round shaft with the linear bearings or the versa mount guide and block and rail?
Most likly will use the round rail and linear bearing for the Y and Z axis. Planning on using the compleate system from Candcnc Plazpak-1.
Any ideas or sugguestion?
Great web site by the way, I learned a lot so far.....
Dave
Igus Rail DDM Linear and Rotary Motion 11 01-17-2008 02:26 PM
Trapezoidal Screw With IGUS Nut kkilst CNC Wood Router Project Log 0 04-17-2007 08:10 AM
IGUS W Linear Rails Kemper73 Linear and Rotary Motion 27 07-20-2005 12:45 PM
Igus versus skate bearing carlnpa Mechanical Calculations/Engineering Design 3 07-06-2005 11:48 AM
Igus E Chain at Alltronics for $2.49 for 15" fyffe555 DIY-CNC Router Table Machines 3 12-11-2003 05:52 PM
