Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-15-2007, 03:00 AM
Paraprop is on a distinguished road
roller screw versus ball screw.
Considering an application like the retrofit of a Bridgeport Knee Mill , is there any advantage to substitute the classical ground ball screw (32mm diameter, 5 mm lead, 13 micro m. / 300mm) by a roller screw like the ones manufactured by SKF ?
Daniel
Old 04-15-2007, 04:14 AM
Zumba is on a distinguished road
It's similar to the comparison between a needle roller bearing and a ball bearing. Rollers larger contact patches than balls, which equates to higher load capacity. The Nook website shows that a 25mm x 5mm roller screw has an 11000lb dynamic load rating, whereas a 25mm x 5mm ballscrew has a 2000 lb rating.
But a bigger contact patch means more friction of course, so it'll limit your top speed. Again, just like how the max RPM of a roller bearing is typically much lower than that of a ball bearing.
Speed won't really matter on a Bridgeport, but neither will load capacity, since the screw is definitely not the weak link on a BP mill. Did you find a pre-owned set of screws? If you're buying new, I'd just stick with ballscrews.
Old 04-15-2007, 04:21 AM
Thanks for the advise.
I'll try to get a set of ground ball screws then. Don't trust second hand ones.
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 08:49 AM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 08:06 AM
