Results 1 to 2 of 2
Thread: B/S Acme R&P
    Registered lgalla's Avatar
    Jul 2006
    canada
    B/S Acme R&P
    Another which is better or cost effective.
    Acme's are 30% efficient,ballscrews 90%.I read somewhere ground ballscrews are made with machines with acme screws???Does anyone like their acme screws?Is there an efficency rating on R&P?On the THK online store a rolled ballscrew,25/05 is$217for2000mm and $154 for the nut.Is this cost effective compared to R&P?I guess my confusion is the huge differences in pricing on these units depending on source.
    Larry
    Mar 2006
    Larry, Make sure you are comparing apples to apples and both apples are Macintosh. There are ballsrews (rolled in various degrees of accuracy and ground in various degrees of accuracy) ACME leadscrews Cut (ditto) & ground (ditto) & rolled (ditto).
    Then there is the "corrected" ACME you speak of that is a "MASTER". Those were made by removing any errors left after original machine manufacturing. Some are scraped, lapped or whatever it takes to get them as near to perfect as possible. The very best are kept as "artifacts" to which others are compared for error. The old SIP leadscrew comparators had a cam on the dial to move the pointer to compensate for the known error in the machines leadscrew. Clever stuff dating back 100 yrs.
    DZASTR
  1. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum CNCzone Club House
    Last Post: 11-16-2006, 06:47 AM
  2. acme rod
    By tomcook in forum Linear and Rotary Motion
    Last Post: 03-24-2006, 06:55 PM
  3. Ab Acme Nut???
    By MMT in forum General Waterjet
    Last Post: 02-27-2005, 09:53 PM
  4. what acme tap do I need for the Enco ACME rod?
    By AJ_Mac2001 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2004, 08:24 AM
  5. Acme Tap
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 02-26-2004, 12:06 AM
