Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-13-2007, 02:23 PM
kylecroft is on a distinguished road
Question Cheap coupler between stepper and allthread
Hi
I am trying to build a linear slide. I have a small unipolar stepper motor. The shaft is a gear (see pic) that measures 5/16" from the end of one tooth to the opposite tooth. I want to couple this to a 1/4" or 5/16" all-threaded rod. I would like to be able to do this cheap (<$15) and I would prefer to be able to get the parts at a local hardware store.
Any suggestions?
Kyle
Old 04-13-2007, 02:30 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
You could do it for next to free if you use a piece of stiff hose or tubing.
Your pic did not attach, by the way.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 04-13-2007, 02:40 PM
Oops, here's the pic. I wasn't able to get a very good pic, but I'll put this one up anyways. About the tube: do you suggest epoxying or just friction-fitting the tube onto the rod and motor?
Thanks for the reply,
Kyle
Old 04-13-2007, 07:10 PM
the__extreme is on a distinguished road
I don't know how cheap or crude you're looking to go here but...
You could epoxy a 1/4" T-nut to the gear. Look up weld nut on mcmaster.com. You could expect some serious misalignment though!
You could also get some wood dowling, drill a 1/4" hole in it, jam the gear into one end and thread the rod into the other. This would be for a 5/16" threaded rod. Probably want to glue the gear in place also.
The tubing is also a good idea, allows your joint the flexibility for misalignment. I'd go with the tube. Depending on what size you get, it should hold without epoxy: http://www.8linx.com/cnc/day6.htm
- Shawn
Old 04-13-2007, 07:35 PM
Thanks for the reply!
I think I'll go with the tube. Thanks for the picture, too!
Kyle
Old 04-13-2007, 08:59 PM
SORCHEROR is on a distinguished road
cant you remove the gear from the shaft?what size motor is that?are you making just one?
Old 04-13-2007, 09:01 PM
you have a unipolar driver for them yet?
Old 04-13-2007, 09:03 PM
I suppose I could remove the gear using this method:
http://www.beam-online.com/Robots/Tu...ger/pager.html
but that would just make a bigger size difference between the rod and shaft.
I don't know what you want for the size
Yes, I'm only making one
And I have a Linnistepper for the driver.
Old 04-13-2007, 10:52 PM
well i guess your best bet is the stiff tubing and some clamps
steve
Coupler between stepper and slide ball screw DeviousMW Linear and Rotary Motion 4 04-07-2007 10:16 PM
Helical Coupler for Stepper -> Rotary Table patmul General Metal Working Machines 3 11-22-2006 12:32 PM
Cheap, small, stepper Pic Driver II Ragnarok Stepper Motors and Drives 1 07-01-2006 09:40 PM
Is there some cheap stepper motor driver? ezland00 General Electronics Discussion 3 03-25-2004 08:20 PM
Possible CHEAP drivers, stepper and/or servo NeoMoses General Electronics Discussion 5 03-23-2004 01:45 PM
