Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-07-2007, 04:20 PM
jimluu is on a distinguished road
What is a tapped rod?
I saw a tapped rod on vxb.com. What is a tapped rod?
http://www.vxb.com/page/bearings/PRO...ystems/Kit7615
Old 04-07-2007, 08:12 PM
That rod is made of case hardened material. It is sometimes supplied with tapped holes in order to fasten the rod to a support rail. That support rail is normally used with the slotted linear bushing shown on that link.
DZASTR
Old 04-07-2007, 10:12 PM
Thanks for the reply. Do you know where one would find rail supports that's compatible?
Old 04-08-2007, 05:23 PM
Probably @ VXB.COM
DZASTR
Old 04-08-2007, 09:50 PM
magick_man is on a distinguished road
well actually they dont sell supports for their rails.
i am using the same 20mm rails on my machine and i had to build my own support blocks.
~Magick_Man~
Old 04-09-2007, 01:35 PM
jimluu, It appears Magick-Man has the answer unless the hole pattern matches another supplier like Thomson, SKF etc.
DZASTR
Old 04-09-2007, 03:23 PM
Thanks. I wonder if I run 3 parallel 1.5" or 2" rails per side for my x-axis that the flex will be acceptable. Trying to avoid making my own supports. I'll be using a trim router so I think my 36" gantry will be around 40bls tops.
RFQ for tapped aluminum rods Unabiker Employment Opportunity 16 02-20-2007 02:26 PM
24V center tapped transformer hericlj General Electronics Discussion 3 09-08-2006 08:41 PM
Pre-Tapped R&P? hardyn Linear and Rotary Motion 0 11-29-2005 02:22 PM
Has anyone tapped a drill rod? WarrenW DIY-CNC Router Table Machines 6 10-26-2005 02:06 PM
Are sherlines drilled and tapped?? BriteHarry Mini Lathe 1 10-14-2004 07:36 PM
