Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-06-2007, 10:01 AM
andrewbishop66 is on a distinguished road
ball screw backlash
I'm having troble with backlash on my ball screws wich is about 11 tho
this is the ball nut I,m using http://cgi.ebay.co.uk/Ballnut-25x5-B...QQcmdZViewItem
I think the problem is that I left the deflector room to move inside the sleve/cups I made this is fitted on a bridgeport clone x and y same backlash no movment on the bearings ect. The nut is 40 mm dia and I used two cups to clamp the nuts in the yoke anyone got any suggestions I think that I need to make a sleve so that the deflector can't flex out
Thanks for reading
Old 04-06-2007, 02:43 PM
svenakela is on a distinguished road
It's not a problem. Either you squeeze the "deflector" with thin steel/brass foil, for example the ones used to line up jigs in machines. Or you make it adjustable from the outside with an adjusting screw by drilling a hole in the sleeve/cup with a fine thread. You can also make the middle of the sleeve like a clamp so you can tighten it over the deflector.
I have the same Isel nuts and they are very easy to adjust.
Regards,
Sven
Old 04-06-2007, 04:03 PM
Thanks I do that
Andrew
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
Ball lead screw backlash problems titchener Linear and Rotary Motion 7 09-13-2005 03:34 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Ball Screw Backlash rocks101 DIY-CNC Router Table Machines 2 03-04-2005 08:35 AM
Ball screw backlash options Stevie General Metal Working Machines 22 11-08-2004 11:32 AM
