Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-03-2007, 11:01 PM
DeviousMW is on a distinguished road
Coupler between stepper and slide ball screw
I was able to great a really nice precision THK linear
slide with a 6mm ball screw and 8 inchs of travel
for my Z axis on my Plasma. Now I need to couple
a 1/4" shaft nema 23 300oz stepper to the 6mm shaft.
Any suggestions on what coupler to use?
The 6mm shaft doesnt have a flat spot so I need
a clamp type coupler. Obviously I want virtually zero
backlash to keep the Z axis as precise as possible but
allow a slight bit of misalignment in the coupler.
Thanks,
Mike
Old 04-04-2007, 06:28 PM
Oldmanandhistoy is on a distinguished road
Do a search for “Lovejoy couplers” here on the zone.
John
Old 04-05-2007, 07:39 PM
tpworks's Avatar
tpworks is on a distinguished road
I believe this might be what you are looking for.
https://sdp-si.com/eStore/PartDetail...784&GroupID=55
https://sdp-si.com/eStore/PartDetail...50&GroupID=981
Old 04-07-2007, 04:49 PM
will gilmore is on a distinguished road
www.mcmaster.com search for "Helical Beam Coupler"
Old 04-07-2007, 10:16 PM
These are perfect!.. I've never seen mm to inch couplers. And the prices are
reasonable for this type of coupler. Most quote I was getting were near a $100. $30 is much better.
Thanks,
Mike
Coupling stepper to ball screw garagefela Linear and Rotary Motion 9 08-18-2006 05:51 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Making a coupler between motor and lead screw nikolatesla20 Mechanical Calculations/Engineering Design 8 07-30-2005 01:05 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
