| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| This is the only remaining piece of the puzzle for this m/c. Somebody please give me a hand and point me in the right direction, I think I know which ones to use but am not sure. Have to design it before putting it together. |
| I use angular contact. I hope that helps. Good luck to your project. ____________________________ Emerson service manuals - Download Emerson service manuals |
| what i did was simple.my lead screws where 1/2-10,so i got 1/2 diameter I.D. angular contact bearings to slit over the outer dia. of the lead screw,than used some 1/2-10 acme nuts on each side of the bearings to lock them on the screw,the nuts need one side faced down smaller so not to rub on the outer race,works great,you dont have to turn down and rethread the end of the lead screw, you could use collars,but nuts are way better,i used locktight and drilled one set screw in the nuts also,you only need to do this on one end,the other end of the screw just needs one bearing to support it from whipping,the motor end i used two bearing,put a washer between them,(with a O.D. smaller than the bearings outer race),this way the bearing are spaced,than you can tight the two nuts fully and lock them,than you sandwich the outer races between two peices and tighten them until there no play in the bearings,i used one plate and screwed it agaisnt the router frame,so the frame was my other plate,works great,and its simple steve |
| Here's what I did. http://www.cnczone.com/forums/showpo...5&postcount=83
| I did pretty much the same thing as Gerry. I'm thinking of replacing the bolts with locking shaft collars and possible seeing if I can replace the while thing with flange bearings, though these may be a little to stiff.
__________________ If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do? Steven |
#10
| Thanks Brian. Joe of the Joe machines just told me the same thing. I tried Dumpsters new site, but no pictures yet (all broken links).
#11
| I don't like those setups. The way I understand it is that you are to have a combination axial & radial load bearing, but these angular contact bearings are not thrust they are semi-angular. I figured that tapered roller bearings would be the proper way to do it. Why did you all use angular instead? Plus, if you do use those, you have the problem of added friction on the thrust/axial part of the bearing, even if it can take the axial load you are adding alot of extra unnecessary turning friction. That makes no sense to me. |
#12
| I did it my way because it was less than $5. Nook uses angular contact in their very expensive blocks. Also, I think I read a few weeks ago that tapered rollers have more friction because the ends of the rollers are actually sliding.
| installing ball screw bearings | dgalaxy | Bridgeport and Hardinge Mills | 12 | 09-01-2006 09:06 AM |
| Bearings for screw drives | futura | Mechanical Calculations/Engineering Design | 13 | 01-12-2006 09:09 PM |
| Lead Screw Bearings - Cheap is OK | musicmkr | Mechanical Calculations/Engineering Design | 6 | 01-07-2006 05:21 PM |
| Lead Screw Bearings | Novah | Benchtop Machines | 4 | 01-05-2006 07:18 PM |
| Ball screw without bearings? | Halfnutz | General Metalwork Discussion | 6 | 06-13-2005 03:10 PM |
