Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-21-2007, 12:26 PM
flash319 is on a distinguished road
Z axis THK flat or Round linear bearing
I am in the design stage of my router/plasma table. I am building it for the router but may plan down the road to use it for plasma. This will be a 3.5(travel) feet by 8 feet table. Anyway, what is the preferance with the Z axis? Much cheaper to use ground shaft and linear bearings but I see a lot of people using THK style rail bearings for the Z axis. I want to run 2 parallel linears (round or flat) say 5-6 inches apart with a ballscrew down the middle. I was thinking 3/4 inch shaft with bearings? Should I consider rail style bearings instead? What would the advantage be? Less flex? I am going for about 8" of travel so my shafts or rails will need to be around 14-16 inches long depending on my final design. What are some thoughts?
Old 03-21-2007, 12:30 PM
ger21's Avatar
THK's are stronger, and easier to mount. Just bolt em on to a flat plate. But they cost more.
I used 3/4" round shaft on my router, with 8" of travel. 18" shafts, with 16-1/2" exposed. I have a set of 18" THK's for my next router. I actually paid less for the THK's on Ebay
Old 03-24-2007, 09:57 AM
jans123 is on a distinguished road
Must it be two parallell linear bearings? It is almost impossible to get them perfectly parallel to avoid forcés built up between them. Using one good linear bearing and a simple flat iron guide with some ball bearings at some distancefro the linear bearing to prevent whatever you are guiding to rotate around the linear bearing is simple, cheeper and easier to align as the only precision device is a single guide (the linear bearing).
/jan
Old 03-24-2007, 10:08 AM
I guess a single would work but there is less rigidity with just the one. I see your point and will take a look at a design like that. I think it would be more work as well to do it with a single as the bearing supports for rotation would require some engineering. Think Think Think.................
Old 03-24-2007, 05:37 PM
Perhaps this link can help:
http://www.cnczone.com/forums/showthread.php?t=14228
(I don't know if the link works...)
I'm mot sure if it is much less rigid
/jan
Old 03-24-2007, 07:23 PM
Zumba is on a distinguished road
/jan
The proper way to install the rails is to treat one as the master and the other as the slave. Should be self explanatory.... when done correctly, the bearings will not bind.
Adding a "flat iron guide with some ball bearings" to combat moment forces may prevent breakage but won't help you at all as far as accuracy. This is not the place to save money.
Old 03-26-2007, 02:26 AM
Armstrong is on a distinguished road
THK's is just the best. I hope your project will be very nice if you use it. Good luck with your work.
____________________________
Philiips Service Manuals - Download free Philips service manuals
Bearing carriage running on an angle profile instead of using round tube Menno JGRO Router Table Design 8 01-02-2007 06:00 AM
Linear bearings - round or square? kerino Linear and Rotary Motion 5 02-24-2006 08:56 AM
cheap round rail linear guide stand-offs? hardyn Linear and Rotary Motion 8 12-21-2005 09:09 PM
round rod for linear motion? tigpro Linear and Rotary Motion 7 08-15-2005 10:08 AM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
