Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-18-2007, 03:19 PM
justCNCit is on a distinguished road
Encoders
Haven't been able to find any linear encoders. They are on all the mills at school, although I'm not sure they are the kind best fitted to CNC applications.
I'm building a router using a stepper drive and it's about 6' long and 3.5' wide.
I'm trying to plan ahead, counting on the fact that some work may end up being scrapped because of missing steps & resonant frequency issues.
Also, I wanted to go with linear encoders rather than rotary, because rotary does not account for ACME screw backlash. However I imagine a 6' long linear encoder won't be cheap.
What are your guys thoughts on this?
Old 03-18-2007, 03:23 PM
Al_The_Man's Avatar
With a 6ft long router, what resolution are you seeking to justify a 6ft long scale?
Believe me you don't want to know the price, even if you can get one.
I know of no commercial plasma or router table that uses or needs scales that large.
Also I personally would forget the acme screw method.
There are some very acurate tables out there using rack and pinion.
Old 03-21-2007, 07:18 PM
I spent about the last year researching ACME screws, don't know a thing about rack & pinion, save that it looks pretty sloppy & not to mention probably pretty expensive.
This is one of those cheap setups, I'll be giving dumpsterCNC some business. So I'll be sticking with ACME for this M/C.
Even so, encoders would still be needed. I figure maybe a rotary encoder on the gantry that tracks on the frame somehow might be an idea to develop on.
Old 03-21-2007, 07:28 PM
Al_The_Man's Avatar
Rack & pinion is the method of choice of most manufacturers, not sloppy if done correctly, it is also fairly economical.
A rotary encoder that tracks the Gantry will probabally entail a rack of some sort, anyway.
Try to get a look at some commercial gantry's to compare methods also.
Old 03-21-2007, 11:56 PM
Fifty_ohm is on a distinguished road
Check out this site for a solution to your actual table movement with rotary encoder. http://bellsouthpwp.net/A/r/Arts_home_page/DRO1/
I've seen this type of setup used before and it can be highly accurate depending on the effective gear ratio of the pulleys.
"Good judgement comes from experience, and a lot of that comes from bad judgment." - Will Rogers
Encoders seb fontan General Electronics Discussion 1 09-27-2005 03:28 PM
Which encoders? heathmanc Servo Motors and Drives 4 06-09-2005 10:02 PM
Encoders-to be-or not to be George Stepper Motors and Drives 2 02-16-2005 02:08 PM
Encoders !! Auzze General Electronics Discussion 3 07-26-2004 07:06 AM
