| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Obviously I'm a newbie and I have an opportunity to pick up a 25" travel ballscrew. Am I thinking right that if the thing has 25" of true travel than that should be good enough for a 24" desired working area. I'm thinking 24" of travel + 1/4" each side for optical limit switch + 1/4" each side for a little spare. |
If it is a router gantry, say 3" wide, you will loose a couple of inches there. then there is the Z-axis, with a router attached, there is an inch or 2, assuming you have the z-axis off centre. I'd suggest your usuable travel is more like 18", maybe 20" Cheers, Peter.
__________________ ------------------------------------------------- Homann Designs - http://www.homanndesigns.com |
| The Y axis will still have the same problem. The Z-axis will be 3-4" wide, so you will loose this. Cheers, Peter.
| Uh, 25" of travel is 25" of travel. Don't see the problem. You won't loose any of it unless you design it in a way that interferes with full travel. Edit: when you make your gantry, usually the desired travel + the width of the y truck assembly will determine width of gantry. If the overall length of the ballscrew is not long enough, you can move the ballscrew support bearing to the inboard side of the gantry upright. You should be able to get full travel. (Also assuming the 25" of travel means you've accounted for the length of the ballscrew nut) Last edited by aspenelm; 03-16-2007 at 01:31 PM. |
| Hmmm...I'm pretty new at this too but I think aspenelm is right. If your ballscrew has 25 inches of travel, you just need to design your machine to not interfere with that travel. It might mean that your ballscrew won't span the width of your machine. The usable travel on linear slides on the other hand needs to account for how wide you want to space the trucks/carriages for rigidity. Just make sure your ballscrew has 25 inches of travel (thread length minus length of ballnut) rather than just 25 inches of thread. Edit: That's funny, aspenelm just edited his post while I was writing this one. They basically say the same thing! Back to real work for me.... |
| Uh, 25" of travel is 25" of travel. Sure looked like that when I drew it on paper. Just wanted to make sure there were no gotchas. In reality I guess in all 3 axis's travel=travel, the big question is always how much EXTRA RAIL LENGTH is needed over the travel length which is obviously a big variable from design to design. |
Peter.
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 09:53 AM |
| Has anyone looked at the "JET" or "Shop Fox" manual machines? | boosted | General Metal Working Machines | 12 | 03-04-2007 09:33 PM |
| Advance notice "Easy CNC" book to be available soon | imserv | Product Announcements & Manufacturer News | 2 | 08-08-2005 10:22 AM |
| Try "CAMback easy" and win one of 10 licenses! | CNCadmin | CNCzone Site News and Contests | 132 | 08-14-2004 11:58 PM |
| Download "CAMback easy"! | CAMback | General CAM Discussion | 3 | 07-06-2004 09:24 AM |
