| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
While building machines using skate bearings and round pipe (gas pipe, EMT...) is cheap and easy, there are some limitations. A major one that I noticed is that you can't get the bearing really tight because the 45° loading puts too much axial load on the bearings, which greatly increases the rolling friction. I came up with this idea to eliminate that problem. Use a laminated wood rail for stability, and epoxy steel rails to it for the bearings to ride on. If you own a wood planar, it's easy to get two parallel surfaces for the top and bottom bearings. The bottom bearings need to be mounted with an eccentric bushing to be able to keep the assembly tight to the rails. I think the easiest route is to buy the chinese dual V eccentric bushings, and some 3/8" ID bearings for the bottom. VXB has 3/8"ID bearings 10 for $15. Any thoughts?
| Nice design; thank you for sharing. Do you think there could be a problem with the bolts running through the top and bottom bearings bending with the pressure? I suppose it will depend on how long they needed to be? Just an observation not a criticism. Wish I had your CAD skills btw. John |
| Very interesting idea. You get a lot of rigidity from the ibeam thickness and the lamination improves the stability of the wood and gives dimensional strength. Don't know much about this type of linear system but would trapezoidal give you better offsetting/sharing/dampening of lateral forces. Oops, maybe I'm looking at it backwards! Last edited by jsage; 03-10-2007 at 08:31 PM. |
| Excellent idea! I know it may be overkill but based on John's comments, I would extend the top and bottom bolts longer and duplicate it on the other side. In otherwords, add a steel plate on the other side and put bearings on that side also. The top and bottom bolts would just extend through the angle on the other side. Unless you could drill the holes just right, you could make then adjustable with the size of the holes so it can be tightened to the steel plates. If you didn't want to add another bearing set on the opposite side, then just use longer bolts on the top and bottom with spacers and put a metal plate on the outside with those bolts connected. This will reinforce it with the weight of the gantry. Just my two cents... Warren
__________________ LetterCAM CNC Software http://www.LetterCAM.com |
Better than a rap around approach which would mean back to the unsupported rail; there is plenty of length to add more bearing to share the load if it were required of course. John |
#10
The main purpose of this design was to eliminate the axial loads and have the bearings only carrying radial loads. I would think that the 4 bearings should be able to carry far more weight than I would need them to. The only drawback is that the table needs to be suspended, to allow the gantry sides to be pulled together under the table.
#11
John Last edited by Oldmanandhistoy; 03-21-2007 at 06:45 PM. |
#12
| Now you've got me thinking what if I mount the rail near the bottom, and have the gantry side straddle the rail. One problem might be that a "trough" would be created that might fill with dust and chips. I'll think about this for a bit.
| Gas Pipe Alternative? | JavaDog | DIY-CNC Router Table Machines | 8 | 01-07-2011 10:24 AM |
| round and round we go | omegaghost | Benchtop Machines | 5 | 01-10-2007 10:25 AM |
| Round Numbers | stampman | Fanuc | 4 | 09-05-2006 06:12 PM |
| emt conduit, galvanized pipe or black pipe? | JohnG | DIY-CNC Router Table Machines | 5 | 05-21-2006 08:24 PM |
| Round corners | slawsonb | SheetCam | 15 | 01-26-2006 04:22 PM |
