| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
To make a long story short... I'm designing a 48x36 router, stainless steel shafts, linear bearings, etc. After pricing aluminum shaft supports, I'm toying with the idea of creating a silicone mold and using polyurethane resin to create the rails at a much lower cost. I think it will be strong enough. It will be bolted to the shafts and to a steel frame. It will there simply to keep the shafts from deflecting. Has anyone tried this stuff for structural components of a router? If it fails, I can always reuse the silicone mold and try my hand at lost wax casting with aluminum |
| Thanks for the input. I've seen PU shaft end supports on eBay, thought it might just work for a full length shaft support. Anyway, I have about 3 gallons of this stuff, 1 part resin, 1 part hardener. Dries hard in 2 1/2 minutes, full cure in 24 hours. Machines well. Shrinkage seems to be about .001 per inch. If it doesn't work for the rails, I'll have to find another use for it. |
| I also bet it will work -- if they are full length supports, they'll only be loaded in compression, and that loading will be spread over a huge surface area, so you shouldn't see much stress (and hence not much movement). Even for crappy plastic, you'll have an ultimate stress of ~1-4 ksi (as opposed to 45 ksi for aluminum). At a conservative 1 ksi, assuming your support is 1/2" wide, and your load is spread over 6" (for 3 square inches), you'd have to see 3000 lbs before failure, and probably 200 lbs before significant mushing of the material. |
| RFQ-Polyurethane parts. | SCCoupe | Employment Opportunity | 7 | 09-19-2007 11:40 AM |
| Polyurethane / Aluminum Machinability ? | RMARCH | General Material Machining Solutions | 1 | 07-23-2006 06:53 PM |
| Polyurethane enamel | MrRage | General Metal Working Machines | 5 | 12-27-2005 11:03 AM |
| Machining polyurethane? | MrHorsepower | Glass, Plastic and Stone | 7 | 12-08-2005 12:27 AM |
| Support For Gas Pipe Rails | Mr.Chips | DIY-CNC Router Table Machines | 26 | 02-17-2004 08:12 AM |
