Results 1 to 5 of 5
Thread: X and Y axis rod questions
    Mar 2007
    The World
    I have recently ran into trouble with my cnc machine, it wouldn’t move on the axis anymore so I had to open it and fix it, I took care of that problem but when putting it back together I saw a spring on the rod that it travels on for the axis. I was confused on what the purpose of that spring was and just wanted to know if anyone can help me understand it. I have taken two pictures to show the area I am talking about.
    Thank you
    http://img301.imageshack.us/img301/7476/spring1ln0.jpg
    http://img339.imageshack.us/img339/5169/spring2mm0.jpg
    Mar 2007
    Turkey
    i think they are working there..
    they should have beed put there for fastening the miniscule spaces between screw chucks... thats my idea
    Mar 2006
    Anti-backlash device?
    DZASTR
    Sep 2006
    Anti-backlash! The secondary leadnut is tightened towards the primary until the backlash disapears. The springs are just there to provide an opposing force as you tighten the bolts.
    Feb 2007
    you need to turn the bolts till the make contact with the backlash nut,the springs keep tension so it doesnt loosen during operation,its an anti-backlash nut,you tighten the bolts until you have near zero backlash
    1. 3 Axis CNC Router capability questions
      By dan2004 in forum WoodWorking
      Last Post: 12-17-2006, 08:13 PM
    2. 5th Axis head rotation questions.
      By whiteriver in forum DIY CNC Router Table Machines
      Last Post: 11-19-2005, 02:07 PM
    3. 4th axis and suggestions/questions
      By DAB_Design in forum NCPlot G-Code editor / backplotter
      Last Post: 04-13-2005, 08:54 PM
    4. Multiple axis questions
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 03-03-2004, 09:52 AM
    5. 4-axis and Contorler questions and power supply
      By wakeboard in forum DIY CNC Router Table Machines
      Last Post: 01-13-2004, 06:40 PM
