Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-02-2007, 10:01 PM
eloid is on a distinguished road
need source for rack and pinion in canada
need source a good source for rack and pinion in grears ontario canada,
20 pitch with 14 1/2° Pressure Angle Spur Gears or 20° pitch dia of 1"
looking for pre drilled Ready-Mount Gear Racks ...
looking for hardned racks if price is good.
Old 03-02-2007, 10:19 PM
lgalla's Avatar
lgalla is on a distinguished road
try www.stdsteel.com/gear.htm
From the Mechmate forum really cheap.
Old 03-03-2007, 09:19 AM
DSL PWR is on a distinguished road
IMO it isn't worth your time to screw around with ready mount gear rack. Just spot weld it to your frame. It doesn't wear that quickly, and when it does just tear it off and 2 minutes with a grinder and you are good to go!
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 03-03-2007, 11:07 AM
Yesterday 08:19 PM
IMO, in theory it sound wondeful ...but its not so in all cases... doesnt work so well if the frame is aluminum
Old 03-03-2007, 02:31 PM
Lol, I guess you need some special rod that can weld steel to aluminum then...
Old 03-03-2007, 06:56 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Arrow Ontario Source for Rack & Pinion
Try CBS Equipment for rack & pinions.
Six locations in Ontario, helpful to deal with, & have a web site you can Google.
PS...(For that steel to aluminum welded connection, you need to fill a hollow elderberry twig with iron filings & wrap with aluminum foil. ------This will only work on machines that have AC straight polarity settings.)
Old 11-11-2008, 11:26 PM
Wolfesmetalfab is on a distinguished road
old post i know, but was searching and found it. You could make small clamps that hold it down with bolts, without actually having holes in the rack.
I need rack and pinion Help t0m CNC Plasma and Waterjet Machines 9 11-16-2005 01:14 PM
rack and pinion planescott Mechanical Calculations/Engineering Design 4 10-11-2005 03:28 AM
Rack and Pinion Hillman Linear and Rotary Motion 1 08-09-2005 04:14 PM
Rack & pinion coolman DIY-CNC Router Table Machines 3 11-30-2004 10:57 AM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
