Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-16-2007, 11:00 AM
rodjava is on a distinguished road
Looking for source for compatible THK LR rails
I'm looking for a source to buy compaible THK LR type rails.
I have THK HSR-35 HB 1 SS bearings.
Is there a website that sells actual THK LR and compatible rails?
Thanks in advance.
Rod
Old 02-16-2007, 05:28 PM
ger21's Avatar
http://www.tos-world.com/webapp/wcs/...11901&msgFlg=Y
Old 02-16-2007, 06:05 PM
Gerry,
Thanks for the link.
I didn't realize until now how great a deal I got on my THK components on Ebay.
I won 8 THK HSR35 blocks and 1, 99" rail for only $345.
A single 80" rail at the website you mentioned sells for more than $300.
I'm now looking for a source that sells rails that are compatible to THK rails. I'm hoping that they might be priced lower than the originals.
Any ideas?
Thanks again.
Rod
Old 02-16-2007, 06:51 PM
walter's Avatar
Gold Member
walter is on a distinguished road
How about Ebay?
Old 02-16-2007, 07:17 PM
lgalla's Avatar
lgalla is on a distinguished road
Hiwin rails and blocks are 1/2 the price of thk's www.automation4less.com
There are interchange charts between the major manfactures,but this is not for mixing different parts.The charts are for similar performance not direct compatibitily
Simply put THK blocks on THK rails. Hiwin blocks on Hiwin rail.No such thing as aftermarket rails for your blocks.
Larry
Old 02-16-2007, 07:27 PM
trubleshtr is on a distinguished road
Funny, I have been looking for a cheap THK type rail too, and ended up at HiWin also.
menomana
Old 02-16-2007, 07:42 PM
www.snsautomation.com
Mississauga location for any Canuck's in the crowd.
menomana
Old 02-17-2007, 01:20 AM
Thank you to everybody who responed so far.
It looks like Hiwin has a interchangeable rail for my THK HSR35 blocks. They are about $100 cheaper than the original THK rails.
I'm pretty confident that the Hiwin rails will perform identical to THK.
Anybody care to comment?
Rod
Old 02-17-2007, 01:24 AM
I just reread Larry's message anld now know that I should not mix rails and blocks.
I will keep a eye out on Ebay for some THK rails.
Rod
Old 02-17-2007, 03:21 AM
Zumba is on a distinguished road
Rod, your assessment in your last post is correct. THKs and Hiwins are only DIMENSIONALLY interchangeable. That is, rail bolt spacing, block PLUS rail height, and block bolt pattern. Everything else is proprietary and unique.
My advice: cut down that long rail for Y and Z axes. Find a different set for your X. This is a good lesson for other ebay rail hunters out there... ALWAYS BUY IN PAIRS.
  #11   Ban this user!
Old 02-17-2007, 10:14 AM
Zuma,
Thanks, I always intended to cut the single 99" rail down to size.
Anybody know the best way to cut THK rails? I have a metal band saw with a bi-metal blade and cooling system. I heard that the only way to cut it is with a "blue stone"???
Rod
  #12   Ban this user!
Old 02-17-2007, 10:25 AM
Soon after starting this thread I sent a email to Hiwin and now it's confirmed.
Rod - unfortunately, the rails and blocks are interchangeable
dimensionally
only as a set. A Hiwin block will not fit on a THK rail and vice
versa.
Thanks for the inquiry. Sorry we cannot help.
Ken Weaver
ken@automation4less.com
8020 compatible rails? jseiler Linear and Rotary Motion 1 03-05-2007 08:31 AM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 02:21 PM
gecko compatible dgalaxy Bridgeport and Hardinge Mills 2 06-04-2006 11:28 AM
TTL Compatible controller metalhacker Open Source Controller Boards 2 05-23-2005 12:25 AM
Are CAT and BT compatible? ETNOM General Metal Working Machines 2 12-16-2004 07:08 AM
