Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-23-2007, 04:17 PM
jseiler is on a distinguished road
8020 compatible rails?
I was searching the web and found this:
http://www.alexproducts.com/CatalogPDF.shtml
If you click on linear motion, you'll see this co has steel rail guides
that fit 8020 type extrusion. I was wondering if anyone had any
comments about this type of rail?
-J
Old 03-05-2007, 08:31 AM
http://www.alexproducts.com/PDF/Section4.pdf
page 8. It clamps and holds 10mm rail in a t-slot.
In progress - 8020, linear rails, ball screws, steppers stevespo CNC Wood Router Project Log 123 03-02-2012 05:43 PM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 02:21 PM
gecko compatible dgalaxy Bridgeport and Hardinge Mills 2 06-04-2006 11:28 AM
TTL Compatible controller metalhacker Open Source Controller Boards 2 05-23-2005 12:25 AM
Are CAT and BT compatible? ETNOM General Metal Working Machines 2 12-16-2004 07:08 AM
