Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-22-2007, 02:31 PM
elogicca is on a distinguished road
Planetary Gearboxes
Not sure where to post this but i am looking for 3 planetary gear boxes 10:1 parallel or offset shaft.. anyone have any good sources?
Old 01-22-2007, 02:44 PM
Zumba is on a distinguished road
SDP/SI has them.. https://sdp-si.com/eStore/
Gearheads -> Planetary
They come in all the standard NEMA sizes but they're $$$$$$$.
Old 01-22-2007, 02:56 PM
Al_The_Man's Avatar
If you have the time, I get mine off ebay, Bayside or Alpha Gear.
Old 01-22-2007, 07:11 PM
Jason Ross is on a distinguished road
Typically planetary gearboxes do not have offset shafts. You could save a ton of money if you could use a spur gear. But if you need Planetary in addition to the names above try Mechtrol, CGI, Neugart. They will be marginally lower priced than the ones above
Old 01-23-2007, 08:37 AM
Moderator
JerryFlyGuy is on a distinguished road
And Thompson.
Also, I'm not sure you can get them down in the 10:1 range but Harmonic drives might be another route? See them sometimes on Ebay.
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
Old 01-23-2007, 12:22 PM
rippersoft is on a distinguished road
Here's another:
http://www.surpluscenter.com/sort.as...s&keyword=PGRI
Reduction gearboxes on servos-good thing? Splint Linear and Rotary Motion 10 05-28-2008 12:32 AM
Cutting a planetary gear... WilliamD General Metalwork Discussion 11 11-09-2006 02:56 PM
Planetary Reducers JerryFlyGuy Mechanical Calculations/Engineering Design 6 01-28-2006 01:03 AM
4th axis- planetary vs harmonic? walter DIY-CNC Router Table Machines 4 10-02-2005 10:46 PM
Gearboxes for Steppers vacpress General Metal Working Machines 1 07-16-2004 11:48 PM
