Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-20-2007, 02:12 PM
clembrant is on a distinguished road
Lead screw making noise
I just built a router using 5/8-8 lead screw. When I jog it the lead screw makes a thumping noise. I replaced the lead screw, but it still does it. I just wanted to know if anybody had run into this and what they did to resolve it.
Old 01-20-2007, 06:03 PM
svenakela is on a distinguished road
Clembrant,
I don't get it, is it a one-sound-per-revolution-think or a constant noise?
Did you check your alignment and that the nut is ok?
Regards,
Sven
Old 01-20-2007, 07:05 PM
2muchstuff is on a distinguished road
How much shaft endplay is there or is the nut on the shaft have play in it. If the shaft has endplay then I would suggest 2 angular contact bearings set opposite of each other with some tension between them.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 01-21-2007, 10:13 AM
I took motor off today and found noise was coming from motor. Didn't notice it before because it wasn't very noticeable until hooked to machine. It is one thump per rev. I'm using xylotex at 1/8 step.
Old 01-21-2007, 03:41 PM
Ok, great you found it. Do you manage to repair it or do you replace?
Regards,
Sven
Old 01-22-2007, 07:33 PM
I contacted xylotec and they said my computer is probably too slow to run mach 2 software. I'm going to try turbo cnc and see what happens
Old 01-25-2007, 01:06 PM
Fixittt is on a distinguished road
Its probably resonence in the motor. Alot of Xylotex users have had this problem.
Here is my thread on my machine and how Im going about solving the issue.
http://www.cnczone.com/forums/showthread.php?t=30988
Old 01-26-2007, 06:06 PM
I hooked my faster computer and it fixed my thumping problem, but now I have a new problem. I'm getting vibration at higher speeds. Right now I'm maxed out at around 32 ipm.
Old 01-26-2007, 06:20 PM
jeffs555's Avatar
jeffs555 is on a distinguished road
How long is your screw? What kind of bearings do you have on it, and how are they arranged?
Old 01-27-2007, 03:46 AM
Make sure everything is aligned and that the screws are "tensioned" properly. Screws tend to flex a lot when they are loose.
--S
  #11   Ban this user!
Old 01-27-2007, 06:31 AM
I've got double angular contact bearings on both sides, tension is pulled to one side. Other side floats(slip fit) in bearing and connects to stepper motor.
ID:	30415   Click image for larger version
ID:	30416   Click image for larger version
ID:	30417   Click image for larger version
Old 01-27-2007, 09:48 AM
But then the screw itself isn't "stretched". If the screw is only fixed in one end it will tend to vibrate as it can move in the other. By tension I mean that it should be tensioned as you do with a rubber band.
Hope that helps.
Regards,
Sven
lead screw nut making ? max_imum2000 Linear and Rotary Motion 19 10-08-2008 12:06 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Making a coupler between motor and lead screw nikolatesla20 Mechanical Calculations/Engineering Design 8 07-30-2005 01:05 PM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 08:06 AM
