Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-29-2006, 08:47 PM
blau_schuh is on a distinguished road
Anyone using THK SR30's and have then mounted vertically for x or z axis?
THK specifies that the best use is a horizontal mount, but im wondering if they will work for my x axis.
Is this a bad idea?
Old 12-30-2006, 12:25 PM
Kevin Taylor is on a distinguished road
Do you mean the rail verticly or are you talking about the bearing orintion I'v been studing this stuff for a plasma and a lathe retro I'v taken ones off of other machines that where mounted everywich way I gues doing more reading on the manufactures spec's is the best bet and looking at store bought equipment Gool luck Kevin
Old 12-30-2006, 12:41 PM
the SR30s are recommended to be mounted flat/horizontally. The HSRs can be mounted in any orientation.
Id like to mount them so that the bearing blocks are at a 90 degree angle with respect to the ground, and the rail ends will be horizontal with respect to the ground. This is for the x gantry axis (at least i thin the terminology is x axis)
Old 12-30-2006, 01:43 PM
Zumba is on a distinguished road
Yes I have done it with zero problems. SR30s are such overkill for most applications that you'll probably experience the same.
Take a look at the THK support site: https://tech.thk.com/ There are two buttons in the center of the page that say "click here". Click on the top one.
It says for the SR30 blocks, the dynamic load rating (in kilo-newtons) is
30kN (radial),
18.6kN (reverse radial), and
16.8kN (side).
In comparison, an HSR30 block has 28-28-28 dynamic load ratings... the same for every direction.
16.8kN = 3776 lbs. I think you'd agree that even that is overkill for anything short of a large commercial router or full sized VMC.
Old 12-31-2006, 03:13 PM
30kN (radial),
16.8kN (side).
Thanks for the info... geez, looks like i could get away with sr15's. sr20.
Looks like one axis is going to be mutant-sized.
Also, thanks for reminding me of the old conversion from physics... 2.2*16800/(9.8)
