Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-27-2006, 07:39 PM
Zumba is on a distinguished road
Ballnut wipers
Are you using ballnut wipers on woodworking machines? If so, where did you get them and how much did you pay?
Old 12-28-2006, 06:48 PM
Nobody's using wipers? I don't know whether to rejoice at my potential cost savings or be a bit alarmed at the thought of potential bearing failures...
Old 12-30-2006, 04:24 PM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
Hi Zumba,
I'm not using wipers because I bought the cheap ballscrews but I am thinking of having a greased leather strap/thonging hanging over the groove with a lead weight on it so it tracks with the screw to wipe the gunk off before it gets in the ball nut. I used to use these on my pushbike years ago to keep the axle clean and they last for years on a smooth surface. Not the best solution but it's a start with 2 either side of the nut.
The Neuron.
I am not completely useless.......I can always serve as a BAD example.
