Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-21-2006, 01:32 AM
ProDrawerCom
IQChallenged is on a distinguished road
HIWIN linear guide too tight
I have some HIWIN linear guides that I bought on eBay. One of them is very tight and hard to push (by hand) while the other three are far easier to push. Is there any way to adjust these things?
Old 12-21-2006, 03:36 AM
svenakela is on a distinguished road
Usually they are tight as standard but the more pressure you put on them, the better they glide. Try to load it with your body weight and slide it. It should run smoothly then.
This is not specific for Hiwin, all guide brands are similar.
Regards,
Sven
Old 12-21-2006, 04:49 AM
ProDrawerCom
No. I'm talking about a level of resistance that 2x the rest of them. Surely there must be a prescribed tension (range).
Old 12-21-2006, 10:04 AM
ViperTX is on a distinguished road
Check the part numbers to the HiWin site.....generally you can buy them with different preloads.....
Old 12-21-2006, 02:19 PM
Check if it has adjustable preload.
DZASTR
