| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
How exactly are ground ballscrews made? I'm sure they start off with some pretty accurate diameter shaft, then use some sort of lathe apparatus to cut the threads. Or do they use a grinder? I'm guessing the screw on the lathe must be pretty accurate. I'm asking because I'm looking into getting some linear motors, with a tool post grinder, and setting something up to make ground ballscrews. The linear motor would act as the screw, and result in a very acurate lead on the screw. Just wondering if anyone has information on how they are made. |
| Essentially they machine cut a special "thread" (ergo a ball groove) and surprise, they GRIND the groove to the desired radius'd shape after final heat treat. A very precise lead screw drives both the cutting tool and the finish grinder. Natually, supporting the shaft is critical to keep the flex from distorting the groove or compromising the accuracy of the groove lead and shape. |
