| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
In a box of surplus equipment that I bought, there were two crossed-roller slides like http://www.techno-isel.com/lmc/Produ...dardSlides.htm Has anyone successfully motorized one? In my case, "successfully" would be mounting a leadscrew and motor without excessive overhang/side forces, and leaving room to mount a Wolfgang Engineering high-speed spindle. I don't quite see a clean way to do it. The application is the Z axis for a very small but very accurate milling machine to make model steam locomotive wheels (CNC-turn the blank and then mill out the spokes and other face detail.) Thanks! Randy |
| That's why I come here for information. I have a Techno/Isel Machine, Thoes are used for side rails on the gantry Y and router head X and maybe the Z with recirculating ball lead screws. My machine is 6 years old, still very accurate a solid machine. Just their Web forum and some parts of their site need improving. |
| Those look pretty cool. I imagine they would be pretty accurate as well. I have a large crossed roller slide, but it's fully setup with dual slides and a carriage with ground ballscrew and motor mount. If you are only using one of these, I think you would have to mount both sides to a plate and then gor from there. This does have mounting holes on top and bottom, right?
__________________ Lee |
| These aren't the big Techno slides (I recently sold a Techno XYZ gantry, so I know all about them.) Forget I said Techno, it was just a convenient link. Pretend I said Deltron... ![]() My slides don't have a manufacturer's name on them. But they look like the following. They are about 5 inches long and have a 3-inch stroke, more than plenty for what I want to do. Randy |
| But I hadn't thought of adding plates--I was thinking of trying to use the slide as is to keep the moving weight down. Thanks for the nudge--I will think on that. Randy |
#10
| I haven't done much on this yet, jmytyk. The motor with leadscrew needs to be fixed to one half of the slide, and the nut to the other half. And there needs to be room to mount the fixed half to the machine structure, and mount a spindle or other payload to the moving half. The slide is pretty small, and there is almost no meat to attach things to the ends of the slide, so it pretty much needs plates attached. I have two of the slides, and am actually thinking of attaching them back-to-back flanking a support pillar to make my Z axis. The pillar can be hogged out in the middle (to make a kind of thick-walled channel) to mount the leadscrew nut and clearance for the leadscrew, and the moving halves connected by a thickwall angle, which cantilevers back to mount the stepper. Quick'n'dirty sketch below. Randy |
#11
| I got my Z-axis finished with the slide you were talking about, check it out- let me know if you have any comments http://www.cnczone.com/forums/showpo...7&postcount=54 _Jon |
