| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
#49
| Larry, belt drive is virtually the same as rack and pinion. If you need to gear one, you'd need to gear both of them. There's no difference if using a pinion with a 1" pitch diameter on a gear rack vs a pulley with a 1" pitch diameter on a belt. Belt drive would be slightly more expensive because belts cost more than gear rack, and pulleys a little more than pinion gears.
#50
Hi I have most of my gear to ready to convert my chinese mill to CNC. A local here has done it to his mill which is the same as mine. I am in the process of replacing the acme threads on my mill and have been searching for ball csrews but in doing that I came accross this site http://www.nexengroup.com/rps/ its very interesting...wait for the video to load Attached is a couple of pics of his mill |
#51
Gates manufactures their new Poly Chain GT belts with carbon in place of aramid fibers, check it out: http://www.gatesprograms.com/ptsavin...nothingtougher I've been looking into a belt drive solution for a filament winding design I've been working on and will most likely settle for something cheaper than this but if I had the money I'd go with carbon belts for sure! Thanks for all the info people! |
#52
| If you'd be prepared to DIY, why not consider something like this linear cam drive? http://www.cim.mcgill.ca/~rmsl/Index...pers/slide.pdf |
| Linear Motion FAQ | Cutters Cove | DIY-CNC Router Table Machines | 6 | 09-30-2009 01:36 AM |
| Rack & pinion | coolman | DIY-CNC Router Table Machines | 6 | 05-07-2006 04:14 PM |
| Lead screw whip | spalm | DIY-CNC Router Table Machines | 3 | 05-24-2005 02:04 PM |
| How to machine a 56 Rockwell lead screw | bgolash | General Metalwork Discussion | 6 | 12-05-2004 03:25 AM |
| Rack & pinion | coolman | DIY-CNC Router Table Machines | 3 | 11-30-2004 10:57 AM |
