Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-09-2006, 08:59 PM
spunky1974's Avatar
spunky1974 is on a distinguished road
FINALLY.....I found some extruded dovetails.....
I've been looking for these for a long time .....thought I'd share the find....
http://www.thorlabs.com/NewGroupPage...Visual_ID=1874
When architects and engineers fail ......my phone rings....go figure! LOL What next?
Old 11-09-2006, 11:30 PM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
That is a great product. I just can't think how to use it. What are your ideas for integrating this into a machine?
Old 11-09-2006, 11:57 PM
spunky1974's Avatar
Well, How about on every axis. I was thinking about delrin slides or uhmw. In making mills I've always preferred the tried and true dovetail. I'm still working out the exact structure for cost effectivness and rigidity. There is so much potential with this my heads spinning. When I get a drawing done tommorrow I'll post it here....stay tuned ..... I have to post some drawings and parts lists in my other post aswell so I have to make time.....till then
Old 11-10-2006, 03:25 AM
epineh is on a distinguished road
That is pretty cool, could make for a fast 3 axis setup, thanks for posting.
Russell.
Old 11-11-2006, 12:16 AM
txcowdog's Avatar
Gold Member
I like the idea of the extrusions I just did not see Delrin slides on the web site. Can you post a supplier of Delrin or UHMW? With Delrin slides this would make a machine build very easy and very fast. Great find.
Old 11-11-2006, 04:45 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
http://www.8020.net/PDF/Fractional%20Section%209.pdf
Old 11-12-2006, 12:41 AM
txcowdog's Avatar
Gold Member
Switcher,
Thanks for the link but I read all 32 pages of the pdf and did not find a Delrin slide that would fit the dovetail for this particular extrusion. Spunky, do you have a link for the slides?
Old 11-12-2006, 07:40 AM
spunky1974's Avatar
There are no links to delrin or UHMW dovetail slides ......I just make my own from sheet stock. It can be purchased at sites such as www.onlinemetals.com.
Old 11-13-2006, 12:32 AM
txcowdog's Avatar
Gold Member
Thanks spunky. Great product. I'll get some and do a little experimenting.
Old 11-13-2006, 10:12 AM
WilliamD is on a distinguished road
Are these aluminum or steel?
  #11   Ban this user!
Old 11-19-2006, 05:20 PM
ahren's Avatar
ahren is on a distinguished road
I'd be a little skeptical of using these in a linear motion application if they are aluminum. Aluminum tends to gall when moving against itself, and is typically not a great bearing medium. That's why 8020 uses UHMW for motion applications (as opposed to static positioning). I've seen a couple of routers on the zone built using the stuff. If you're planning on this for building a DIY router/mill, you defrinitely want to drive your gantry/table in the middle to keep it from binding, but it's definitely do-able.
  #12   Ban this user!
Old 11-20-2006, 11:21 PM
yugami is on a distinguished road
What angle dovetail are these? Could be good if you could machine up bearings to match.
