Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-02-2006, 01:25 PM
ammar is on a distinguished road
steper+gecko201+2" /turn b/s driver ... help
hello all
I have step motor 4 Amp 1.8 deg
gecko drive 201
ball scrow 1 turn= 2" movement
I try to make a 2mx2m cnc router ... lettle big
the quistion i s what is the good rate of gear in betoween step motor
and ball/scrow ... to optain good speed without step-loss in movement
up to now.. and for no load .. I could run the motor as maximum speed
as 600 rpm only...... at 60 volt 3.5 amp adjust at the drive..
any help.. ???
thanks
Old 11-05-2006, 08:24 AM
ger21's Avatar
How much torque does the stepper have? What's the steppers rated voltage? What's the diameter of the screw? How much weight are you moving.
For a ballpark figure, I'd say 4:1, so 1 turn of the motor = 1/2" of movement
Old 11-05-2006, 01:44 PM
NC Cams is on a distinguished road
You may find this thread to be of help:
http://www.cnczone.com/forums/showth...078#post214078,
Specifically, post #15
