Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-23-2006, 01:20 AM
cjchands is on a distinguished road
Arrow Coupler questions for first time builder? Please advice.
Hi guys,
I am a first time building mini CNC using hobbyCNC kits 200oz in and X2 mini mill. I got stuck in deciding weather to connect steppers directly to the leadscrew or shall I use the belt drive to increase the torque of the steppers. I have done NEITHER one of those!.
Anyway, upon realizing 2 things: 1. cost and 2. time, I think I might go with the 1st choice that skipping the belt and go directly with the leadscrew connect to the steppers like many pictures I have seen in the forum.
I disassemble my X2 leadscrew and measure 3/8" dia and stepers 1/2".
So any recommendation where can I find the couplers that would fit directly into them? You advice is appreciate it.
Old 10-23-2006, 08:45 AM
rippersoft is on a distinguished road
Use Lovejoy connectors. Get the same type of connector, such as L-050, but one with a 3/8th bore and the other with a 1/2 bore. A spider sits snuggly in between the 2 halves.
I use this on 3/8th leadscrew and 1/4" stepper shaft. Works good. Follow the link to a surplus outlet and compare prices.
http://www.surpluscenter.com/sort.as...s&keyword=PSF3
RipperSoftware
Old 10-23-2006, 11:55 AM
Thanks so much Rippersoft. Appreciate it.
Old 10-23-2006, 12:32 PM
ger21's Avatar
Mcmaster Carr has them (last time I looked) cheaper than the surplus center, and they deliver a lot faster.
Old 10-24-2006, 11:37 AM
truman is on a distinguished road
dumpster cnc has really nice ones threaded on one end and shaft diameter on the othere that is what I am using.
Rob
Old 11-02-2006, 12:04 PM
Ed_R is on a distinguished road
I need some cusstom-made jobbies, I think. I bet Tim at Dumpster can help me. I think tonight I;m going to go through and analyze what exactly I need to do to get my machine to where I'm happy with it, and then compare that bottom line to buying a new one. If I can find a decent 24X18 or better machine for under $5K I migth do it anyway.
