Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-17-2006, 04:14 PM
xyz100 is on a distinguished road
Long Lead screw support
Is there a way of supporting long (8 feet) lead screw in the middle?
Old 07-17-2006, 07:30 PM
2muchstuff is on a distinguished road
It is a support, sort of. It is called a rotating nut design. The lead screw is mounted stationary and the nut revolves around the screw. It's a bit more complicated and more expensive to create.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 07-17-2006, 07:34 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Fascinating!
I supposed you could use 3 nuts--the usual on the piece you're driving plus 2 "steady rest" nuts. The latter two would be attached to blocks on linear ways and their sole purpose would be to track along to provide support.
It really depends on your application. Not sure how well this would work. You could imagine on a lathe where you release the nut that it wouldn't work well at all.
Best,
BW
Old 07-18-2006, 09:40 AM
Essencially, when all axis are in "home" there is no support as far as I can see. Hence it can wobble if not thick enough. I guess the only way to fight it is to choose bigger leadscrew. Which adds mass and inertia to the system. Oh well.
Old 07-19-2006, 04:24 PM
Zumba is on a distinguished road
If your lead screw needs support, that means it's too small. You can put slight tension on it, but you'll need good angular contact bearings on each side of the screw to take on the force.
If you're on a limited budget, rack & pinion is your answer to long lengths, not thin leadscrews.
Old 08-14-2006, 12:06 PM
Andis is on a distinguished road
Hi !
Such support, uses SCM ( woodworking cnc routers) .
In this case ball screw is fixed and nut is rolling.
At his moment I have not picture,but if you need, after some days,
I can send you some pics.
andisk@tvnet.lv
Old 08-14-2006, 04:20 PM
Chagrin is on a distinguished road
I wouldn't necessarily classify rotating nuts as "more expensive". For example, with a servo system, to switch to rack and pinion will usually require 1) two racks 2) two motors 3) a bunch of gears to slow down each servo ... you get the idea. It really adds up in complexity and time.
Yeah I'm being picky. I just hate to see the rotating nut concept panned so easily.
Old 08-21-2006, 04:03 PM
I'ts no so tragic.
Of course,it's necessarily to have rotating nut. It's special construction.
But I'm not agree,that necessarily bunch of gears and another stuff.
Only difference is,that rotating nut can't be direct motor driven.
In this case it's necessarily to use pulleys and ribbed belt.
No question about two motors and two racks.
Old 11-02-2006, 07:42 AM
synthetiklone is on a distinguished road
Just a suggestion / idea for long existing router tables: What about some form of support that drops away as the gantry comes near, or a rotating support, so the gantry gently pushes a lever to move the support bearing out of the way! Has this been done?
To get away with such a long leadscrew (2.4 meters) I decided to use a flat (cog type) toothed sections bolted to the frame (easy to align therefore unlimited length attainable) Then my stepper motor cog ran directly on this rail. I only had 1/3 mm resolution, but this is ok for polystyrene foam cutting. You could use a reduction gear to obtain better resolution. X and Y axis are both the same design.
Old 11-02-2006, 01:00 PM
Andis, If you want to drive a nut directly from the motor, why not use a hollow shaft motor? They are available from many suppliers.
DZASTR
  #11   Ban this user!
Old 11-07-2006, 12:13 PM
spunky1974's Avatar
spunky1974 is on a distinguished road
This threads been here awhile but I thought I'd drop a suggestion....check out the post.
How to support long lead screws....a solution
  #12   Ban this user!
Old 11-07-2006, 12:40 PM
eman5oh is on a distinguished road
I remember someone had a design that used spring loaded flaps that provided support for the screw and when that gantry and nut hit it, it would just fold down. I remember several of them being used along the length of the screw. Not sure how well it worked, thought I would pass along the info though.
Everything in moderation, including moderation.
