Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #13   Ban this user!
Old 11-09-2006, 08:38 PM
C.Michael is on a distinguished road
Hi there everyone !!as you can see this is my first post..But I am sure there will be lots more coming..I am just starting with this cnc, so maybe there is a reason for this being a bad idea..what about using a screw drive of a garage door opener..The housing is usually made of extruded alluminum with lots of area to bolt up to..the screw is totally supported all the way ..and you use the thinghy that hooks up to the door that travels down the length of the screw to move your axis..it has a great track built into it to keep it straight also...
Old 11-09-2006, 11:36 PM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
Garagedoor opener!! Great idea. For $100 you get an 8' mounted leadscrew and a rigid piece of extrusion. What a deal.
  #15   Ban this user!
Old 11-10-2006, 02:29 PM
I imagine the garage door opener idea can be developed. I hope your application requires the accuracy etc. of a garage door.
DZASTR
  #16   Ban this user!
Old 11-10-2006, 04:47 PM
Let us know when you come up with an idea Richard and we will all come along to throw a bit of sarcasim on it..If you look at a screw drive of a opener,it actually is a decent piece of workmanship..the carriage puts a small preload on it and the center section of the setup could be added to ,to have a longer setup..the flat backbone of the aluminum extrution already has holes drilled in it to mount to your design..any more ideas??..Richard??
  #17   Ban this user!
Old 11-10-2006, 05:56 PM
C.Michael, Sorry if I ruffled your feathers, I thought you were kidding. My background is high precision machining, less than .001" tolerances. For relaxation I used to build & race boats. +/- 1/32" tolerances. I do not believe a 5/8-11 ACME door opener threaded rod will give me the accuracy I require. However, I did find some projects where you can use the door opener screws. Machining of rigid foam that is later covered with fabric etc. There the tolerances are in the area of 1/16". Might be able to hold that. That is "garage door tolerances"
Peace
DZASTR
  #18   Ban this user!
Old 11-11-2006, 11:10 AM
C.Michael,
After more thought, there probably is a place for the garage door leadscrews in a router. Roughing out styrofoam patterns, surfboards etc. Somebody might be able to use them. My apologies for speaking without enough thought.
DZASTR
  #19   Ban this user!
Old 11-17-2006, 04:25 AM
synthetiklone is on a distinguished road
Another source of g-door tolerance parts!
Hi all, Sorry about the title, but I just I couldnt resist it, however...
Awesome idea - the garage door threads, Im sure with the right loading and gearing it could be quite an accurate setup..
Another awesome idea follows..
Interestingly enough, since I have been developing my CNC machines here in New Zealand, where it's impossible to find standard parts you guys are simply buying at wall-mart or similar places I have been spotting all sorts of interesting things that could be used in a DIY/homemade/#8 fence wire type of CNC setup. (#8 fence wire is a Kiwi (NZ'er) joke that most NZ'ers are DIY'ers that can accomplish anything with a piece of number 8 fencing wire! heh, uhm, me included) anyway, I digress...
I found in a simple sturdy, strong, SCISSOR JACK for jacking up your vehicle, in the car boot (you guys call it the "trunk" I think It has a rather nice 8 inch (according to the missus threaded rod! and even the wide nut seems to fit very snugly with no backlash! Check out a few differant types as this one was quite clean looking compared to others I have seen before.
A worth while consideration to be explored in the near future.. especially in NZ where our local bearing supplier wants over a thousand NZ$ for a threaded rod/nut arrangement 300mm long!
Anyway, hope this is of use to other keen DIY'ers
Will post some piccys of my foam cutter (.3mm resolution direct drive from steppers, no reduction gearing is fine for polystyrene)
And my 900x700x300mm - dual horizontal(!) gantry y-axis rails, with centered z-azis drop, eventually supporting a 300mm deep 3d cutting head, (my 5-axis dream machine).
This machine has 40mm diameter(!) stainless rails, and 40mm threaded rod! no whipping on this mean rod, no matter what the revs!
anyway, is getting late NZ time.. as you can probably tell
bye all, and CNCleep well... till next time..
Tony
  #20   Ban this user!
Old 11-17-2006, 12:30 PM
http://www.genie-garage-door-openers...pair_parts.htm
Take a look at this supplier..What i am trying to design in my head right now is a large mill that will take a sheet of plywood and cut it into pieces to make cabinets..drill all the peg holes and shelf supports..On this wb page there are several pre drilled brackets that could be used to tie it all together..we will see..Thank you ,Synthetiklone for the posting..Mike
  #21   Ban this user!
Old 11-21-2006, 08:41 PM
Bowman's Avatar
Bowman is on a distinguished road
I once thought about how to support a long screw and had that same idea for a push/pull setup where the gantry would pass one way and knock one side down while lifting a support at the rear of the gantry at the same time via a small cable connecting the two with simple roller guides. The supports would be U shaped to cup the screw as closely as possible without putting it in a bind. Something to consider but its only been on the drawing board in my mind so far for me
  #22   Ban this user!
Old 11-21-2006, 10:28 PM
2muchstuff is on a distinguished road
Look for the older screw driven or commercial door openers. They have the longer one piece screws where the newer ones are sectional.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
