Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-30-2006, 10:16 AM
Burn is on a distinguished road
Buying Ground ball Screws
I am looking into building a custom CNC mill from scratch, and I need to figure out what ballscrew I want...I have heard that ground ballscrews are best.
However, I can't decide which brand, length, travel, etc.- Can someone set me straight?
Thanks,
Burn
Old 06-30-2006, 04:12 PM
NC Cams is on a distinguished road
Length and travel are all packaging issue on the machine you're working on.
HIWIN is a noted supplier of ground screws. They have bolt-in ones for Bridgeports of varying lengths for the various axes that are affordable and surely adaptable.
Old 06-30-2006, 04:19 PM
Assuming I go with the Hiwin screws, what model do you reccomend for a build like this? Thanks
Old 06-30-2006, 08:11 PM
It is impossible to make a recommendation - you're "specs" are WAY too generic.
Check out what's available, comparison shop, get a price quote, if it meets your needs and/or budget pull the trigger and buy it.
Old 06-30-2006, 10:37 PM
For starters, what diameter ball screw do you suggest? They will be driven by servoes from IMService, which have 1/4" Diameter shafts.
Old 08-29-2006, 01:32 PM
Tailwheel is on a distinguished road
For hobby type machines, or for more precision for that matter, I see no reason to use ground ballscrews when rolled ballscrews will do the job.
When you make your production setup, you can offset the cutting tool to maintain your dimensions, but the encoder must be first rate in order for the screw to repeat.
Old 08-29-2006, 03:42 PM
phantomcow2 is on a distinguished road
I second hte Hiwin recommendation, I have 3 of their ground ballscrews that I will be using for my X3 CNC. Each one was machined perfectly, allowing about .0002" for a press fit of the duplex bearings inner races. Also, they all came with inspection reports.
If I had to pay though, I would just use rolled ballscrews. Member adobe machine noted .0008" of error over 28" using ROckford 5/8-.2 rolled. I think this is more than adequate for HObby use. Unless that is, you plan to hold a few tenths over 2ft+ lengths.
Old 09-05-2006, 01:09 PM
Zumba is on a distinguished road
"CNC from scratch" - I assume this means a router. You don't need ground ballscrews. A high precision rolled or even avg precision rolled screw will work just fine, as will a single nut.
3/4 inch diameter for lengths up to 6 feet will remain pretty accurate, that is, not flex too much. This applies to any kind of ballscrew. They're all steel anyway. Of course if you go bigger, it'll be less likely to flex.
I'm a bit concerned though that you're asking about what LENGTH ballscrew to buy. Does this mean that if we tell you 5 feet, you're going to go out and buy that exact length? The length of your ballscrew should be roughly the length of your linear rails, which will be roughly a foot longer the travel of that particular axis, X or Y. You haven't even told us exactly what you're making yet.
Buying materials before you design a machine is a great way to waste tons of money. Especially if you buy ground ballscrews.
What metalworking experience do you have, and what machines do you own and plan to use to construct the frame of the router?
Old 09-06-2006, 08:35 AM
Bill Davis is on a distinguished road
linear ball screw ball sizes
I'm looking to replace the ball bearings in thk sr15w slides. can some one tell me the standard size ball or where I can find the info for these units. I hoping to have the replacement balls on hand before I shut down to do this.
thanks
bill
Old 09-06-2006, 10:05 AM
monte55 is on a distinguished road
Acme
Don't mean to change the thread.............are there different grades or hardness of acme thread......I read a post a while back when a guy was going to turn the ends of the acme but said to grind the threads down a bit to get through the hardened part . I just turned my 3/4 x 6 I purchaced
at ENCO........it didn't appear to be hardened at all. Was very easy!
