Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-28-2006, 02:52 PM
snooper is on a distinguished road
Red face FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc )
As a noob I'd like to see:
1. Facts about tables and gantries (what are they, advantages of fixed vs moving).
2. What is offset?
3. Basic construction methods (incl levellling out the important parts).
4. Preferred methods of dealing with backlash, whip, resonance.
5. Which types of bits/tips suit which materials?
If I think of anything else, I'll add it to this wishlist...
Old 06-28-2006, 03:13 PM
Burn is on a distinguished road
2. What is offset?
Same here, I would like to see:
1. Ball screws and lead screws...What are they/what is the difference
2. Things to look for when buying above screws
Old 06-28-2006, 09:58 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cool Uses of Gears in Robotics
Here is an interresting web site explaining backlash in gears!
Backlash in Lead Screws: What It is and What to do About It
Backlash
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 06-28-2006, 10:06 PM
ger21's Avatar
Try this:
Ballscrew Basics
Old 06-28-2006, 10:29 PM
Gold Member
Cool Mechanical Power Transmission
NOOK INDUSTRIES, INC.
Old 06-29-2006, 06:02 AM
andy_ck87028 is on a distinguished road
There is an FAQ forum on this website.
Hopefully it will answer many significant questions and avoid the need for data duplication.
If more contribution is required, this thread could become the forum for identifying where that effort best goes.
Andy
Drat, imperfection has finally stopped working!!
Old 06-30-2006, 06:15 AM
NC Cams is on a distinguished road
Answers to the above and MORE:
Research
CNC Information
specifically post #15
Electronics books
http://www.forrestmims.com
or
http://www.amazon.com/gp/product/pro...lance&n=283155
The "holy grail" of electronics info but a bit deep for the DIY CNC neophyte:
http://www.amazon.com/gp/product/052...lance&n=283155
Linear scales;
http://www.cnczone.com/cg...3;t=003181;p=0
Ball screw basics:
Ball Screws 101
Ball screw treatise, the hard core stuff:
Ballscrew Basics
PID tuning
PID explanations?
Daisychaining ATX power supplies:
http://www.cnczone.com/forums/showth...015#post142015
http://forums.bit-tech.net/showthread.php?t=108208
Linear P/S design/construction
http://www.campbelldesigns.com/files...ply-part-1.pdf
Servo amp P/S design
http://www.elecdesign.com/Articles/A...7635/7635.html
Servo motor , servo amp, powersupply sizing for CNC
http://www.rutex.com/pdf/Mystique2.pdf
Bearing literature:
http://www.bardenbearings.com/literatr.htm
http://www.timken.com/products/bearings/catalogs/
http://www.jp.nsk.com/app01/en/catal...gi?ec=bearings
Get the NSK E1102 catalog for starters
Motor torque info/defininition
http://www.merkle-korff.com/formulas.asp#con
What gage wire to use:
What gage wire?
http://www.cnczone.com/forums/showth...480#post136480
Servo vs Stepper:
Steppers and Servos...
Simply stepper info:
http://www.parkermotion.com/catalog/catalogA/A12.pdf
Stepper reverse engineering:
http://www.doc.ic.ac.uk/~ih/doc/stepper/others/
Stepper sizing:
Sizing Criteria for Torque of Stepper motor
Small stepper and general purpose linear P/S
Old 07-02-2006, 11:13 PM
Thanks for all the replies, it's appreciated!
snooper's second law: common sense isn't as common as we're led to believe...
Old 02-27-2007, 04:31 AM
landart1 is on a distinguished road
Thanks Snooper
Snooper ................you have asked the Question I was looking for and got the answers I was looking for .Much appreciated.
You have the right user name for sure alas Sherlock Holmes!!!!!!!!!!!!!!!!
Regards Glenn Down under OZ.
Old 02-28-2007, 02:17 AM
Old 02-28-2007, 04:55 AM
svenakela is on a distinguished road
There are a couple of sticky's in the Linear motion subforum about... ...eeh... ...linear motion.
And as this thread is more about motion than mechanical engineering I'll move it.
Regards,
Sven
  #12   Ban this user!
Old 02-28-2007, 04:38 PM
andrew888 is on a distinguished road
Question Relevant facts: Making a cnc machine should be in a faq
2. What is offset?
Hello all:
I applaud slooper for asking a most relevant question. I think the
CNCZONE is a wonderful web site, but it lacks organization in getting
newcomers up to speed.
A general FAQ about the most relevant answers to questions about the things needed to make a CNC machine. Once a person gets up to speed with these general answers about the makeup and issues about making a machine, he can ask more specfic questions about making a particular kind of machine.
The CNCZONE is a depositary of creativity and genius, we need to make it where newcomers can share in that genius quickly and easily.
In humble humility,
andrew888
