Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-26-2006, 09:57 PM
SatanKlawz is on a distinguished road
rail problem fixed with a pic!
well if you remember a short while back I was having an issue with a rail system that I had picked out and bought. It was a pair of 60" unsupported rails in a 20mm Diameter. The rails were to be supported at the very ends with a set of mounts. After hearing from you guys about how the rails will flex and distort under a side load I went and found these, same size rails except supported. They were NOT cheap.
Old 06-26-2006, 10:16 PM
ger21's Avatar
But they sure look nice.
Old 06-26-2006, 10:44 PM
Gold Member
Ken_Shea is on a distinguished road
And good bye to any flex under load problem
Old 06-27-2006, 09:58 PM
yeah, this was susposed to be a little home built machine that was to be constructed with electronics for under $500. Those rails alone were almost that.
Old 06-27-2006, 10:40 PM
Gold Member
SatanKlawz,
I am running into the same thing on my project, down the road, neither of us will regret it.
Ken
Old 06-28-2006, 07:00 PM
Jason Marsha is on a distinguished road
In order to keep the machine consistent the other axes should also have those type of rails, I think you can keep the $500.00 for electronics and motors.
Do I see ground ballscrews in this machines future.
Jason
Old 06-28-2006, 07:45 PM
actually it will be acme rod. I am not sure how much of a difference there is but I have all of it already. It is a dual leadscrew design.
