Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-26-2006, 03:33 PM
WayneC is on a distinguished road
How many MM per rev for a wood router?
I'm in the planning stages of upgrading my Shopbot CNC router, which will include a new Z axis with ball screw/stepper motor.
How many MM per revolution should I consider for the Z axis ball screw?
I cut lots of 2D profile cuts, but I also need to be able to do sign work and some moldmaking. So resolution is important, but not critical like a lathe or mill might be.
Thanks for the input!
Wayne from White Salmon
Old 06-26-2006, 05:53 PM
ger21's Avatar
As long as your motor has enough power, I'd say around 10mm, which should give you good speed and still have decent resolution.
