Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-15-2006, 08:32 PM
jdholbrook is on a distinguished road
Linear slides clicking
Just recieved some small, RSR9, rails and trucks off ebay.
One of the trucks makes a regular clicking noise as it's moved.
Is there anything that can be done?
Replace the grease?
Do I dare open one up to check the condition of the bearings?
James
Old 06-17-2006, 11:51 PM
No one has any advice about opening up one of the trucks?
Will the bearings fall out?
Can I put them back in after cleaning and regreasing?
Anyone?
James
Old 06-17-2006, 11:59 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
well do't know what a RSR9 is but pictures you will get better responce.
Old 06-18-2006, 12:03 AM
2muchstuff is on a distinguished road
Do you feel any resistance when you hear the clicking.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 06-18-2006, 08:16 AM
jerber's Avatar
Gold Member
jerber is on a distinguished road
I have some rsr15 rails and trucks. The balls will fall out but it is doable to open them.
Just clamp the truck to the rails and put the balls back one by one when you reassemble.
____________________________________
Jeroen
Old 06-18-2006, 07:01 PM
bigz1's Avatar
bigz1 is on a distinguished road
I have not long bought some THK HSR25 carriages of ebay. 3 of them where hard to push and 1 made a regular clicking noise as you mentioned. I found that 1of the 4 bearings sets in carriage was the suspect and freed up the bearings by pushing them rapidly forwards and backwards. I know it sounds a bit of a bodge job but it seems to work. Probably benifit from the apllication of some more grease (use manufactures recommended).
Old 06-18-2006, 10:40 PM
Thanks for the great replies!!
I don't feel any difference in the resistance of the clicking truck vs the quiet trucks.
It is a very regular clicking and speeds up with faster movement of the truck.
Makes me suspect that there is a flat spotted bearing. The rail is too short to get all the bearings to "rotate" thru the truck.
I did try the pushing it forward and backward rapidly to maybe loosen up the grease.
I also sprayed the rail with WD-40 to try and soften up the existing grease but it still clicks.
This thing is so smal I would imagine the bearings are almost microscopic (especially to my 50 year old eyes)
Where do you get the proper grease?
McMaster maybe?
Thanks again for the replies.
