Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-09-2006, 10:16 PM
ironDigit is on a distinguished road
different ballscrews ?
good evening gentlemen,
i can get some nice occasion ballscrews but they're not all the same type
1 ground ballscrew
and 2 rolled ones
is there anything against puttin all of these in one three axis set-up ??
and were would you guys put the ground one and the other rolled ones ??
thx in advance
Old 06-10-2006, 11:42 AM
Torsten's Avatar
Torsten is on a distinguished road
A ground Ballscrew is likely to run a little smother and be more precise.
It is howerver just one amongst many components that make up the Drivetrain so unless all components are of very high presison it would make little difference.
Rolled Ballscrews quality is sufficent for general Milling applications.
On a Lathe I would be temted to use the higher precision for the X-Axes because it
controlls the Diameter of the Part and operates on the Radius needing twice the resolution.
For a Mill it dose not matter.
Good Luck
