| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| I just won a 15/16-16 tap & GO/NOGO thread plug gage on eBay, I want to make some mounting flanges for the various Ball Nuts which use the 15/16-16 thread! My question is: What design do you prefer? 1. Flat plate with four 1/4" holes, and a 15/16 thread in the center. 2. Round flange with four holes, and thread in center. 3. 90 deg. bracket with 15/16 thread centered on one leg and 4 holes on the other. 4. Triangular plate with 3-holes and thread in center. 5. Dual nut mounting for anti-backlash. 6 something else? Please choose one or more, and explain why! Thanks, Eric
__________________ www.widgitmaster.com It's not what you take away, it's what you are left with that counts! |
| I would prefer the dual nut setup. as far as the configuration if you are offering to sale these, and they were a good price, I think that people would design around them, but I think that it would be nicer if it weren't a flange, but a block that bolts directly to the plate that the ballscrew will need to move. |
| Well, that is how I plan on doing mine, I think it will solve a few problems, one is that you don't have to take the ballnuts off to install the dual ballnuts, another is that you don't need to make a bracket to hold the flange, and another is that the preload is easlily adjustable, the same thing could easily be built for just one ballnut as well. |
A block with holes at 90° to the leadscrew is not a problem, but the 2nd nut needs to be mounted to a plate that is mounted to the block! Then it can be shimmed / adjusted to take up the slop which caused the backlash!
| What do you mean neither does rotating them, if you have two ballnuts, and you rotate 1 of them, you will be able to eliminate your backlash. With one ballnut, there aren't as many advantages to this design, but with two I think that this design would be quite benificial. |
| Your right, I don't know what I was thinking! It works because the thread pitch on the nut is different than the pitch of the lead screw!
