Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-18-2006, 03:54 AM
rhino's Avatar
rhino is on a distinguished road
DIY Ballscrew....?
Out of curiosity, has anyone out here ever built their own ballscrew, i have seen threads and posts on thread screws, but if you had the technology of hard turning at work would building ballscrews be possible?
On the other hand, You have different fingers.
Old 05-18-2006, 04:32 AM
posix is on a distinguished road
it isn't the screw, it's the nut that would be problematic. but I guess you could make that too if you had all the machinery available to you.
Old 05-18-2006, 09:33 AM
NC Cams is on a distinguished road
People do it with threaded rod all the time.
The true trick to a ball screw is that the "groove" is not a true radius. It is more like a gothic arch.
Thus, the groove is actually shaped like this:
\O/
this shape enables you to eliminate ball slop by using larger balls. Otherwise, you'd have a "bowling ball in a gutter" effect which is counter productive to accurate positioning.
"Threading" the ball screw would be done how by the DIY'er?
By using a lathe?
You'd then be using a rolled or cut acme to try to cut a ball screw which at best would be cheap copy of the thread pitch on the baseline acme. Probably be better off using good quality threaded rod (is there such a thing???).
Hardinge made a machine tool lathe that could be used to make a ball screw. They had super precise ball screws on it that had ABEC 9 bearings that were further sorted so as to hold axial lead error to within millionths...
Hmmm. If you owned or had access one of these, why would you even need/consider making your own ball screw??? At some point, the falacy of making EVERYTHING becomes apparent. Ultimately, some stuff is just better off being purchased....
Ultimately, MAKING a machine tool (part or machine) takes a MUCH more accurate machine than the machine component you're trying to make....
Old 05-18-2006, 10:34 AM
greybeard's Avatar
greybeard is on a distinguished road
I agree with the sentiment of your posting, but isn't this -
- a paradox ?
It's like doing jigsaw puzzles in the dark.
Why is there always more error than trial ?
Old 05-18-2006, 01:58 PM
not a paradox but a recursion. who/what makes the machine that makes the accurate machine for making precise machines that make ballscrews? jehovahs witnesses might now chime in by saying "God, of course" but we all know that he is more into spiritual well-being rather than materials science.
but anyway, to get back on track and as nc cams says the point is not to make everything yourself. some things you're just better off buying.
Old 05-18-2006, 02:30 PM
fkaCarel is on a distinguished road
Well he made the world in 6 day's, didn't he? That's material science pushing to the limit. So making an accurate machine for an acurate machine for an accurate machine must be peanuts. So for once I agree with the jehova's. Automatically comes the next question: can one pray for ballscrews?
Carel
Old 05-18-2006, 02:33 PM
pray for ballscrews? now there's an idea...
<gone prayin'>
Old 05-19-2006, 04:22 AM
rhino's Avatar
Dear Big Fella..........
Carel
DEAR BIG FELLA (WITH THE BIG WHITE BEARD) UPSTAIRS.....
PLEASE HELP ME FIND THE INSPIRATION, THE KNOWLEDGE AND THE SKILL TO HELP ME CREATE THE MOST PRECISE/ACCURATE BALLSCREW EVER MADE...
YOURS TRULY,
RHINO
Old 05-19-2006, 08:19 AM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
This is an interesting statement and not strictly true. If it were true, then we would have no machines at all. When the Earth was formed, a super accurate machine would have to have been created to produce all of the inferior, less accurate, machines we have today.
The Gingery book series is a good example of making machines more accurate than the tools used to build them.
He describes building a lathe from scratch with very basic hand tools. Once you get so much built, the lathe actually builds it's self.
Mrbean.
Old 05-19-2006, 09:23 AM
I tend to disagree heartily with Mrbean and here's why:
We make cams from our own designs. In doing so, we see continuous and often predictable profile degradation/deviation trends as you go from design data to the machining master.
There is then more change generated as you go from master to finished cam. We even see differences in the profile when we grind the cam with a "small" (13")versus a big (18") diameter wheel.
Only via empirically derived and applied compensation techniques can we "manage" this in spite of the fact that we've rebuilt and redesigned certain features of our grinder and/or our production processes - the machine simply can't do anything other than what the synergy of its parts will allow - good, bad or indifferent.
There is defininite analog "smoothing" and/or morping that takes place in the manufacturing process which results in profile deviation. Is it enough to matter???
Suffice it to say that it is manageable and/or containable once you learn how to compensate for it. Machine compliance and/or normal tolerances are merely a part of the reason why it is IMPOSSIBLE for even the best analog and some digital equipment to EXACTLY duplicate design intent.
Now, assume you're want to to make an EXACT 10 turns/inch ball screw. If you have ANY lead error in the lead screw of the lathe used to make the ball screw, the BEST you can hope for is to duplicate the lead error in your "master" lead screw (don't forget axial runout potential in the spindle bearings too which gets superimposed as well) - the more probable result will be the amplification/exacerbation of existing lead error - thus, the by-product WON'T/CAN'T be better than the original - ERROR begets error.
Having worked in the bearing industry (machine tools) and now in the cam industry, I know that the reduction of error is MANDATORY as you seek to achieve the production of more precise, error free product. The creation of better machines that do things with less composite error is critical to the creation of lower PPM defects.
  #11   Ban this user!
Old 05-19-2006, 09:42 AM
garagefela is on a distinguished road
Hi all,
I would seem to think that a leadscrew on a lathe would be fairly accurate and if used to manufacture/duplicate a ball screw would be accurate enough for me.
I wonder how much weighting people put on to the accuracy of thier ballscrews, in other words, why did you buy a ballscrew? Was it for the accuracy or was it for the efficiency of it? ie. it spins real easy and little power loss.
Regards M
  #12   Ban this user!
Old 05-19-2006, 09:55 AM
When you work in areas where 0.000100"s of inches makes a difference, the use of precision ground ball screws is pretty much mandatory - a lead screw simply isn't in the same league
(PS there's already been a long exchange on cut vs ground lead screws vs ball screws - this shouldn't be an excuse to resurrect that thread)
When you're shooting BB's at a light bulb at a distance of 2 miles, the utmost in accuracy is essential if you want to hit the target.
If you'r using hand grenades, you can be within several yards and still accomplish your goals.
If you're using thermo nuclear weapons, +/- a mile is close enough.
How close does it (the ball screw) have to be to suit YOUR needs??? ONce you answer that question, you can choose between a rolled or ground or DIY version....
