Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #25   Ban this user!
Old 07-24-2007, 12:10 AM
Wade is on a distinguished road
You can make a more accurate thing, with a less accurate thing. You just need accurate position feedback, to "correct" the error. You need more precise feedback, and steadier tools, not more accurate tools.
  #26   Ban this user!
Old 07-24-2007, 01:20 PM
ironDigit is on a distinguished road
And probably : scrapping a lot of parts is -part- of making ultra precision parts.
thx for digging in guys.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
  #27   Ban this user!
Old 07-24-2007, 03:07 PM
Zumba is on a distinguished road
I think the best example of low precision parts being pieced together to create a high precision assembly would be your typical rotary table.
A phase II rotary table, made in China, is pretty cheaply made, but all the internal gearing, manages to be precise within several minutes of a degree. The same principles could probably be applied to grinding a high precision ballscrew using nothing other than budget gears and acme screws.
  #28   Ban this user!
Old 07-25-2007, 07:48 PM
hmm this could make a nice feedback system when time is not an aspect of your succes.
a feedback for indexing a "high"precision screw that is.
see as long as you got quality men you can make quality tools.
wich again is quite comforting(and i might even be able to sleep again)
cheers Zumba
  #29   Ban this user!
Old 08-03-2007, 11:26 AM
Andre' B is on a distinguished road
Originally Posted by HuFlungDung View Post
I read, or saw a picture somewhere, of a device for making an accurate helix through kinematic methods. The method involved using something similar to a lathe taper attachment, where the guide bar was set parallel to the hypotenuse of the right triangle representing the helix angle of the screw. A system of cables and weights kept the travelling shoe in contact with the guide bar.
Such a device would be as precise as the flat and straight guide bar could be made. There are proven methods to improve flats by manual methods, reducing the errors and improving on the machine that machined the original.
I have not really thought out whether such a contraption could be made to work, but it seems feasible.
Older gun barrel rifling machines also the common method used in home build rifling machines.
http://www.firearmsid.com/Feature%20...anufacture.htm
http://www.benchrest.com/forums/show...?t=25813&pp=15
http://www.cnczone.com/ub...ic/16/631.html
  #30   Ban this user!
Old 08-11-2007, 05:04 PM
toastydeath is on a distinguished road
Master screws were (and sometimes still are) made, first by a fairly accurate "roughing" generation method, either on a lathe, or a grinder, or from a special purpose machine geared to produce a screw without any pre-existing model.
The screws are then hand-worked on one side of the thread face with laps using feedback from special-purpose measuring machines that can continually analyze pitch error. After several iterations, you now have a screw that is more accurate than laboratory gauge blocks.
Ironically, these all have a form similar to an Acme thread or a square thread, because you can't lap a ballscrew.
Then, these master screws are used as length references and go into master thread grinders. The master thread grinders are ultraprecision machines that require a whole building of infrastructure to support their operation. These master screw grinding machines can produce very, very accurate leadscrews fresh off the grinder of any form you desire. The first ones were completely manual machines, and after a period of time, slowly became analog (not cnc) corrected machines. You can go buy a CNC thread grinder that has been profiled and relies on the masters generated by manual methods for its accuracy.
Now, this "artifact" method of using master screws for accurate grinding has been eclipsed by machines that are guided by metrology frames, and use no form of screw whatsoever. Rather, they use capstan drives for linear axis positioning, interferometers for angular and linear feedback, and piezoelectric fast tool servos for final correction at the tool interface.
  #31   Ban this user!
Old 08-13-2007, 10:04 AM
MrWild is on a distinguished road
unsubscribe thread
  #32   Ban this user!
Old 08-14-2007, 05:52 AM
DaveP is on a distinguished road
Rail Extension Kit for Screw Drive Garage Door Opener
I posted this in another thread, but maybe folks here would be interested too.
I was wondering if anyone had ever tried using a screw drive from a garage door opener to drive an axis on a homebrew machine? I wonder how the acuracy compares to threaded rod or belt drive home systems. Not the highest, I am sure, but for woodworking machines it might be ok.
I was searching the sears.com web site looking for a part and saw this item -
Craftsman 8 ft. Rail Extension Kit for Craftsman Screw Drive Garage Door Openers $19.99
