| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Is it better to have a higher reduction gearbox and have a bigger pinion on the rack or less reduction smaller pinion? The gear drives would be Alpha SP planetary 35:1 with 4,000 RPM servos if this is the way to go. Or does it depend of a lot of other things? Thanks
__________________ Dennis |
| If you go with too small of a pinion you will not have enough teeth in contact with the rack. This will cause a condition called jumping when reversing or sudden starts and stops. I know that there is some engineering data out there that calculates the min. number of teeth in contact based on the gears pitch.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
