Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-09-2006, 04:47 AM
Prboz is on a distinguished road
Stauff Clamps
Has anybody experimented with Stauff clamps as linear bearing housings?
They are a green 2 piece plastic clamp with a metal base and top. The base has 2 tapped holes.
I am using 2 on each side of each axis for a 3 axis machine.
Just wondering if anybody else is using the same.
Prboz
More information here http://www.stauff.com/Stauff/china/english/Clamps.asp
Old 05-10-2006, 05:10 AM
gotis is an unknown quantity at this point
There are aluminum clamps as well, think they are used for hydraulic systems.
Old 08-25-2009, 02:25 AM
skatun is on a distinguished road
Stauff
Do u have any pictures of ur machine?
I am thinking about using stauff gr3 clamps filled with grease outside a 25mm aliminum pipe..
Kim
Old 08-25-2009, 05:04 AM
Some Pictures I have.
I Stauff Clamp actually holds a linear bearing.
Prboz
ID:	87310   Click image for larger version
Old 08-25-2009, 05:22 AM
Linear bearing
What kind of steel rod and linear bearing are u using. Stauff clamps are really easy to use.... Do you have more pictures aswell? It looks pretty impressive.. I have just made some corner brackets and some feet. Gonna start with the linear bearings now..
Old 08-26-2009, 05:37 AM
The Rods are just bright Mild steel and the linear bearings I bought off Ebay.
It is only fairly light duty as I cut Radio Controlled Aeroplane parts for Scratch built planes.
I use a dremel as the router and bits up to 1/4"
Have attached 2 more images.
Regards
Prboz
ID:	87373   Click image for larger version
