Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-06-2006, 08:55 AM
Zumba is on a distinguished road
What size ball bearings for linear blocks?
I'm building some linear blocks that will slide along supported Thomson shafting. It will use the 3-bearing design, 120 degrees apart, that many people seem to use.
What size bearings do you folks use? I'm thinking about using 22mm skate bearings.
Old 05-19-2006, 12:22 PM
jhelmstetter's Avatar
*Registered User*
jhelmstetter is on a distinguished road
I am also working on a similar design. I think (I'm at work right now) I am using 20mm skate bearings but only because I have those already. I'm sure 22mm will be just fine.
