Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-27-2006, 06:58 PM
CnC_BoY is on a distinguished road
Exclamation Big enough leadscrew
I'm looking for ACME screw and the only goor solution I found for now is 3/8-10 screws (bigger= a lot more expansive. It will be for a 18*12 table (moving table so about 24 in max unsupported span). I just wondered if those screws are big enough not to flex and whip too much. I don't plan to do very rapid work so I wont spin them at 1000 RPM or domething like that. If tou think it will flex too much, what would be an acceptable span?
Thanks a lot
Old 03-27-2006, 07:03 PM
Also, their anti backlash nuts have a ''Maximum standard preload of 6 lb). Is it enough for my machine. I don't think Dumpster's nuts have more preload than that.
Old 03-27-2006, 07:12 PM
eman5oh is on a distinguished road
Check MSC for keystone Acme screws, they are a lot cheaper than most other places. The 3/8 are IMHO a little on the small side for a 24 inch span, althought they will work.
Everything in moderation, including moderation.
Old 03-27-2006, 08:00 PM
HayTay's Avatar
HayTay is on a distinguished road
ENCO 1/2-10 x 6' ACME Threade Rod for $6.99 + shipping
Check it out! It's where I purchased mine (ACME nuts to match, also). View pictures here: HayTay's ACME rod & nut pictures.
HayTay
HayTay
Don't be the one that stands in the way of your success!
Old 03-27-2006, 09:04 PM
thanks guys, finally I will use 1/2 - 10 with dumpster's nuts
