Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-25-2006, 08:18 AM
keyne is on a distinguished road
Lightbulb V-Rail Options
Dear Zoners,
i compiled a PDF Document with 10 options for rails for V-rollers. It contains a sketch and a couple of descriptions/strong and weak points for each option.
Please take a look and tell me which option you would use or what you have tried and how it worked for you. I will add new comments and new ideas to the PDF.
K
Old 03-25-2006, 09:19 AM
ger21's Avatar
#11 - 2 of the #1's, one top and one bottom, which is the way they are meant to be used. If only used on top, the wheel can rotate a little bit with axial forces. By using the V rollers top and bottom, it eliminates the possibility of side to side play, or flexing.
Old 03-27-2006, 10:41 AM
added #11 and #12.
hope this is useful for some..
Old 03-27-2006, 12:50 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
#11, you can mount the center piece to machine, then use an e-longated (spelling) hole on the top and bottom pieces to bolt to the center piece every 6-8 inches to allow for percise alignment.
Old 03-27-2006, 12:58 PM
rippersoft is on a distinguished road
I use the Unistrut #5 for a moving table. I have 2 rails. The length is ~45" and the table rolls on the outer lips of the unistrut. I use 2 skate bearings separated by a nut. Gives just enough width to grab the rail and stay put. There are 3 sets of bearings on both sides. Table weight holds it in place.
I have seen no issues with flex or overall strength.
RipperSoftware
Old 03-27-2006, 02:28 PM
thanks for the feedback!
keep it coming
