Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-24-2006, 03:41 PM
lemonyx is on a distinguished road
Alternative to Skate Brgs?? Need advide
Need some advice on these, instead of making the roller carraige of skate bearings, what about these?? http://image.inkfrog.com/pix/sherrodsurplus/1071x01.jpg
for all 3 axis??
http://cgi.ebay.com/Thomson-PBO-8-O...1QQcmdZViewItem
Thinking about using these on the jgro and then carring them over on the rebuild. Thought, ideas, suggestions
tia
Old 03-25-2006, 06:50 AM
rippersoft is on a distinguished road
Neat idea. Beefier pillow block, though. Maybe if you used 2 for better support....
RipperSoftware
Old 03-25-2006, 07:09 AM
phantomcow2 is on a distinguished road
That will work.
Also look at the drylin stuff frm Igus, MSC carries it. You can make your own aluminum pillow block for these things, and buy them as inserts.
http://www1.mscdirect.com/CGI/NNSRIT...PMT4NO=6033841
Costs about 2-6 dollars depending on size. Drill rod will work for these, I think McMaster Carr also sells hardened aluminum rod too that will work.
