Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-17-2006, 11:18 AM
DanOSB is on a distinguished road
Timing Belt for 10.5 foot travel axis?
do you have any suggestion which timing belt to use for 10.5 foot axis and we want it to be pretty accurate... and dont want stretch back n forth too much when the gantry is sliding.. the gantry itself with everything on it will weight about 200 pounds and there is no work force (cutting torch/plasma) when cutting the material.. max speed would be about 500 ipm
Old 03-17-2006, 11:49 AM
Karl_T's Avatar
Karl_T is on a distinguished road
That's getting pretty long...
Would roller chain work in your application?
Karl
Old 03-17-2006, 12:50 PM
Al_The_Man's Avatar
You may want to consider http://www.brecoflex.com/ I have used their continuous belting in those lengths, they are made specially for those type of applications.
