Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-12-2006, 02:50 PM
vacpress is on a distinguished road
Thompson SPB-12 or RD10HLFor Z Axis? (pictures)
I am looking to finally build a reasonably good CNC machine, to help build other projects, finally. Anyways, I am looking at these 2 different linear rails from alltronics.com..
I want to use them in a Z axis with 7 to 12" travel on a ballscrew... Moving a portercable router.. A normal size one, if that makes sense..
Thompson Rod 28 inch with Two Pillow Blocks
Thompson rods in good used condition 28 inches long x 3/4 inch diameter. Each rod has two super pillow blocks made by Thompson bearing their model number SPB-12 the cost on these new is well over $200 each, limited supply.
04T020 Unit Price : $49.95
Thompson Rail Extended type Rd10HL
Thompson Slide bearing p/n RD10HL-285 with two AccuGlide pillow bearings p/n CD10AAAH. We have a limited supply of these new 285mm long linear bearings, a generous layer of grease is included. Each AccuGlide block measures about 2.5 x 4 mm and is free to travel the length of the rail and more!
04Z023 $34.95
alltronics: http://www.alltronics.com/robotics.htm
I would like the Travel to be closer to 12"... For some reason I think 2 of the rd10hl would be easier to mount and align.. But probably only 6-7" of travel...
Thanks!
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 03-14-2006, 08:24 PM
Bruggles is on a distinguished road
The accuglide seems a bit small, I would go at least 15 in the square type. The other seem like they might work, but you would probably want to use a different shaft, and limit your travel, the longer the span between shaft supports the more flex you will get.
Old 03-15-2006, 03:52 PM
Went with....
Thank you for the reply..
So, I finally decided on
THK 12" Linear Slide w/ Block # HRW 21 Qty-2 (about 70.00 for both, new! only 1 slide per rail though)
I plan on purchasing 2 more slides, Hopefully.. Otherwise I will have to keep looking...
As for the thomson accuglide rails being to small... Really? I got the impression that this type of rail can handle huge loads...
Thanks for any additional advice!
Robert
