| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
While standing doing some photocopying at the 9 to 5, I found myself needing to clear a "mysterious non existant jam" to have a better look at the innards of the copier. It has a wire drive to control the position of the scanner head, which appears to have virtually no backlash and be very simple, a drum with a fine thread on it, piece of wire wrapped around a few turns in a loop around the scanner head, held in place on the head by similar means to timing belt clamps. I have also seen this system used to raise and lower the elevator on a 737 so it's obviously a reasonably reliable and accurate system. Any drawbacks to using this on a large scale machine that's only going to cut light materials? would certainly beat the price and effort of pretty much every other solution I can think of as I can make it entirely out of scrap in the garage!! |
| I can't see any reason why it coulpn't be used, and I'm surprised I haven't seen anyone else mention it. This system is used in manual analog radio tuners as well, and it maintains perfect accuracy over hundreds of thousands of cycles. I would use a fairly strong, supple cable for the "string", as its important that it not have any stretch, and the system will have to be protected from chips. Span will be limited somewhat due to the influence of gravity on the cable, and the size of the pulley will be very important- it cannot be too large, as the mechanical advantage, and resolution, drops quickly with increasing size, and the possibility of slip has to be addressed as well. The system would be similar to a rack and pinion in terms of resolution/ speed, but far less expensive. The drive pulley would need to be carefully made, though. For inexpensive plasma, it could be just the thing. Might be harder to prevent oscillation in a larger system, though. |
| I thought so, I might just have to give that a go - I'll probably make the machine on an "and/or" approach so I can easily switch to alternative means if needed. My only concern when I sat down with paper and pencil (well, cad) was one you have just pointed out, the diameter of the drum for the wire to wrap around. I think I'll need to gear the motor to the drum which obviously then could introduce backlash. The chap who sold me the motor and boards reckoned I should aim for about 1-2mm movement from a 360 deg rotation of the motor - some serious gearing needed for that. |
| I have a Roland MDX-15 and it uses cable, pulley, drum system. I did some testing with the idea for a larger router, but the cable sagged and stretched too much. I think, it works fine for 12-15" axis, but not for a longer distance. Since ballscrew is $1.23/inch and a matching ball nut is $23/each, I don't think the cable system can beat it. Precision drums and pulleys are expensive. I looked them up a while back, and a 1" dia. drum cost $80. I will stick with preloaded ballscrews, either with over sized ball or double nut. |
| hmmm thats not so good news as my router is going to be large . UNfortunately the cost comparison for me in the UK is a little difference - I can turn up the drums no problem (or indeed beg some off a mate) and the cable can be had for free from my father, whereas the cheapest I've found appropriate ballscrew is £7 ($13?) per 100mm and ball nuts at £50 ($90!) each unless anyone can point me at cheaper in the UK? |
| Everything, Where is it that you are finding those kind of prices on screws? If you would be so kind could you post a link for us. That sounds like just the ticket for my new {in the works} machine. Sorry to highjack Aaron |
| Hijack away Ballscrewed - I want to know that as well!!! at those prices it could almost be worth importing them, though I'm not sure about getting 5.5ft long ballthread through the post from the USA and having it arrive straight!!! |
| Aaron, I found two sources. I think homeshopcnc can machine the end for you. http://homeshopcnc.com/page2.html Or, go to mcmaster.com and search for ballscrew. The 5/8" screw is $1.27 per inch and the matching square ball nut is $23.85 each. You might want to go with 2 ball nuts per screw. I bought other things from mcmaster before and they sell quality stuffs. Sometimes they don't advertise the brand, but I got all brand name items. Let us know how it works out for you. Tan |
| Dongle, Where are you? US has no problem with shipping. I bought 8 foot 1/4" brass, aluminum rods through mail order and they came straight. They were shipped in hard cardboard protective tube, and I could not break the tube in half to dispose it. Just ask them about packaging options. I think DHL ship world wide. Buy insurance. |
#10
| Unfortunately I'm in the UK Tan - our postal service is erm... 'sadly lacking' in most respects - might be worth it but it's a fair bit of cash to spend and have them arrive bananna shape. I'll send them an email and chat it through. If they are properly packaged then they should be OK! |
#12
| to your original question, this type of drive is called a capstan, just like it was used on the old ships. you'll see it on the x axix of manual surface grinders and T&C grinders - places where you want a smooth, sensitive and quick action but don't much care about precision (at least along the x axis). it has no backlash, but a downside is the cable will stretch and the gearing is wrong for most machine's feed rate. Last edited by Mcgyver; 03-07-2006 at 12:20 PM. |
